How can I get the search widget to work again once I have destroyed and recreated a map?
2727
05-06-2016 06:41 AM
SergioBoggio
I am a GIS Specialist but a relative noob when it comes to JavaScript, so bear with me...
I am writing a script that allows users to choose between two different maps, using two different projections, by choosing between two radio buttons. When the user clicks on a radio button, the previous map is destroyed and a new one is created. I can get an on-click event to work on the new map, and I can get the scalebar to work on the new map. However, even though I can see the Search widget, and it does list addresses correctly, when I click on an address, nothing happens.
The refresh of the map is done like this:
map.destroy();
map = new Map("map", {extent: mapextent});
map.addLayer(baseMapLayer);
The scalebar code, which works, is
scalebar.destroy()
scalebar = new Scalebar({map: map, scalebarUnit: "dual"});
If I try the same with the Search widget...
search.destroy();
search = new Search({map: map}, "search");
search.startup();
...then the search isn't displayed at all. If I declare search as a new variable...
search.destroy();
var search = new Search({map: map}, "search");
search.startup();
...then I can see the search widget, and it will list results, but when I click on a result, nothing happens (i.e. no marker is placed on the map and the map doesn't zoom to the location. I would guess it is something to do with the search widget not recognising the new map object, but then why does the scalebar work?
Any help much appreciated.
Tags (1)
RobertScheitlin__GISP
Sergio,
Here is a sample that shows how. The issue is that search.destroy() removed the whole search div from the dom.
<!DOCTYPE HTML>
<html>
<head>
  <meta charset="utf-8">
  <title>Home Extent</title>
  <link rel="stylesheet" href="https://js.arcgis.com/3.16/esri/themes/calcite/dijit/calcite.css">
  <link rel="stylesheet" href="https://js.arcgis.com/3.16/esri/themes/calcite/esri/esri.css">
  <style>
    html, body, #map {
      padding:0;
      margin:0;
      height:100%;
    #search {
     display: block;
     position: absolute;
     z-index: 4;
     top: 20px;
     left: 74px;
    h3 {
         margin: 0 0 5px 0;
         border-bottom: 1px solid #444;
      .shadow {
         box-shadow: 0 0 5px #888;
      #feedback {
         background: #fff;
         color: #444;
         position: absolute;
         font-family: arial;
         height: 300px;
         right: 30px;
         margin: 5px;
         padding: 10px;
         top: 30px;
         width: 300px;
         z-index: 40;
  </style>
  <script src="//js.arcgis.com/3.16/"></script>
  <script>
    var map, search, scalebar;
    require([
      "esri/map",
      "esri/dijit/Search",
      "esri/dijit/Scalebar",
      "dojo/parser",
      "dijit/registry",
      "esri/layers/ArcGISDynamicMapServiceLayer",
      "esri/geometry/Extent",
      "dojo/_base/lang",
      "dojo/on",
      "dojo/dom-construct",
      "dijit/layout/BorderContainer",
      "dijit/layout/ContentPane",
      "dijit/form/RadioButton",
      "dojo/domReady!"
    ], function(
      Map, Search, Scalebar, parser, registry, ArcGISDynamicMapServiceLayer, Extent, lang, on, domConstruct
      parser.parse();
        center: [-56.049, 38.485],
        zoom: 3,
        basemap: "streets"
        map: map
      }, "search");
      search.startup();
        map: map,
        // "dual" displays both miles and kilometers
        // "english" is the default, which displays miles
        // use "metric" for kilometers
      registry.byId("radioOne").on("change", function(isChecked){
  if(isChecked){
          search.destroy();
          scalebar.destroy();
          map.destroy();
            zoom: 3,
            basemap: "streets"
          on(map, "load", lang.hitch(this, function(){
            domConstruct.create("div", {id: 'search'}, "map", "first");
            search.startup();
  }, true);
      registry.byId("radioTwo").on("change", lang.hitch(this, function(isChecked){
  if(isChecked){
          search.destroy();
          scalebar.destroy();
          map.destroy();
            extent: new Extent({xmin:-179.6191629086413,ymin:17.881242000418013,xmax:-65.2442340001989,ymax:71.40623536706858,spatialReference:{wkid:4269}})
          var CensusLayer = new ArcGISDynamicMapServiceLayer("https://sampleserver6.arcgisonline.com/arcgis/rest/services/Census/MapServer", {
            "id": "Census data",
            "opacity": 0.75
          map.addLayers([CensusLayer]);
          var loadEvt = on(map, "layers-add-result", lang.hitch(this, function(){
            search.startup();
            loadEvt.remove();
  }, true));
  </script>
</head>
<body class="calcite">
    <div data-dojo-type="dijit/layout/BorderContainer"
         data-dojo-props="design:'headline', gutters:false"
         style="width: 100%; height: 100%; margin: 0;">
      <div id="map"
           data-dojo-type="dijit/layout/ContentPane"
           data-dojo-props="region:'center'"
           style="overflow:hidden;">
         <div id="search"></div>
         <div id="feedback" class="shadow">
            <h3>Change Map</h3>
            <div id="info">
              <input type="radio" data-dojo-type="dijit/form/RadioButton" name="maps" id="radioOne" checked value="Streets"/> <label for="radioOne">Streets</label> <br />
              <input type="radio" data-dojo-type="dijit/form/RadioButton" name="maps" id="radioTwo" value="Census"/> <label for="radioTwo">Census Data</label> <br />
            </div>
         </div>
      </div>
    </div>
  </body>
</html>
</html>
Sergio,
<!DOCTYPE HTML>
<html>
<head>
  <style>
    html, body, #map {
      padding:0;
      margin:0;
      height:100%;
    #search {
     display: block;
     position: absolute;
     z-index: 4;
     top: 20px;
     left: 74px;
    h3 {
         margin: 0 0 5px 0;
      .shadow {
      #feedback {
         background: #fff;
         color: #444;
         position: absolute;
         font-family: arial;
         height: 300px;
         right: 30px;
         margin: 5px;
         padding: 10px;
         top: 30px;
         width: 300px;
         z-index: 40;
  </style>
  <script>
    require([
      "esri/map",
      "dojo/parser",
      "dijit/registry",
      "dojo/_base/lang",
      "dojo/on",
      "dojo/domReady!"
    ], function(
      parser.parse();
        zoom: 3,
        basemap: "streets"
        map: map
      }, "search");
      search.startup();
        map: map,
  if(isChecked){
          search.destroy();
          scalebar.destroy();
          map.destroy();
            zoom: 3,
            basemap: "streets"
            search.startup();
  }, true);
  if(isChecked){
          search.destroy();
          scalebar.destroy();
          map.destroy();
            "opacity": 0.75
            search.startup();
            loadEvt.remove();
  }, true));
  </script>
</head>
      <div id="map"
            <h3>Change Map</h3>
            <div id="info">
            </div>
         </div>
      </div>
    </div>
  </body>
</html>
</html>
SergioBoggio
Hi Robert,
This is exactly what I needed. Thanks very much for your help!
Sergio
