How can I full screen display  map??
14284
12
05-01-2014 12:30 AM
by Anonymous User
Not applicable
Original User: xiaoyun8786
hello,every superior??
       I have a question,I hope you can lost several minute to look at it??if you can answer my question ??I thanks you very much???
My map is in right of center??now i should add a button  of ???full screen????? if i click the ??? full screen "button, the map display full screen, then  click it the second times, the map back.
    pic A  [ATTACH=CONFIG]33512[/ATTACH]  -- >     B  [ATTACH=CONFIG]33513[/ATTACH] , the yellow render is map  and  the green color is  IE head???
JakeSkinner
Esri Esteemed Contributor
Hi Song,
Here is an example that you can build off of.
JakeSkinner
Hi Song,
by Anonymous User
Not applicable
Dear Mr. JSkinn3:
      Thank you  very very much that  you give  a detail answer to me.
      I wish you happy every day!
                            xiaoyun
                           2014.5.1
xiaoyunnsongb
Dear Mr. JSkinn3:
      Hello, Thanks your again, now I have a  problem, when I click the "full screen" button, the other  panel  is hide,but the map div is not expand to full screen, the display like this fromA [ATTACH=CONFIG]33545[/ATTACH]-->[ATTACH=CONFIG]33546[/ATTACH](I did't write this code(dojo.byId('map').style.display = 'none')),the map is not expand  and the other div is change to blank�??
if I write the code (dojo.byId('map').style.display = 'none')  the display is all blank �??I don�??t know why �??I hope your help again�??
       thanks very much�??
                xiaoyun
              2014.5.2
by Anonymous User
Not applicable
Original User: mariczone
Dear Mr. JSkinn3:
       thanks very much�??
                xiaoyun
              2014.5.2
If u not re-create that map, u must try to reposition() or resize() your map.
If u set style display to none, it's certainly that section will be blank.
xiaoyunnsongb
Dear mariczone :
      Thank you very much for your rapid answer,  I add  map.resize() only  maybe not success , I should give the mapdiv  css set ?
      Wish you  happy every day.
by Anonymous User
Not applicable
I guess that the result that u need is set map contain widget to fullscreen.
1. you must set other widget display style to none, except your map contain widget,
so the result will be this.
2. Then u must re position of that div that contain that map to "top-left" and then set width and height to 100%
3. after that u need to call map.resize() and may be map.reposition() too for resize map to full div.
xiaoyunnsongb
Dear mariczone
this is my code
<body class="claro">
    <div id="mainWindow" dojotype="dijit.layout.BorderContainer" design="headline" gutters="false" style='width:100%; height:100%;'>
        <div id="header" dojotype="dijit.layout.ContentPane" region="top"></div>
        <div dojotype="dijit.layout.ContentPane" id="leftPane" region="left">
            <div dojoType="dijit.layout.AccordionContainer" id="accordion">
                <div dojotype="dijit.layout.ContentPane" title="Legend">
                    <div id="legendDiv"></div>
                </div>
                <div dojotype="dijit.layout.ContentPane" title="Table of Contents">
                    <div id="TOC"></div>
                </div>
            </div>
        </div>
        <div id="mapDiv" dojotype="dijit.layout.ContentPane" region="center">
            <div id="buttonDiv">
                <button dojoType="dijit.form.Button"                    id="fullScreen">FullScreen</button>
            </div>
        </div>
        <div id="footer" dojotype="dijit.layout.ContentPane" region="bottom"></div>
    </div>
</body>
var map;
require([
    "esri/map",
    "dojo/dom", "dojo/on", "dojo/_base/array", "dojo/parser",
    "dojo/dom-construct",
    "dijit/layout/AccordionContainer", "dijit/layout/ContentPane", "dijit/layout/BorderContainer",
    "dojo/domReady!"], function (
Map,
dom, on, array, parser,
domConstruct) {
    parser.parse()
    map = new Map("mapDiv", {
        basemap: "streets",
        center: [-81.792107, 26.150807],
        zoom: 8
        dojo.attr("fullScreen","inEdit",false);
     dojo.connect(dojo.byId("fullScreen"),"onclick",function(evt){
   var inEdit = dojo.attr("fullScreen","inEdit");
         var  changeLabel = "FullScreen";
   if(inEdit == true){
            dom.byId('leftPane').style.display = 'block';
            dom.byId('header').style.display = 'block';
            dom.byId('footer').style.display =  'block';
             dojo.byId('mapDiv').style.width = "20%";
      dojo.byId('mapDiv').style.height = "20%";
   } else {
   dojo.attr("fullScreen","inEdit",true);
   changeLabel = "Back";
            dom.byId('leftPane').style.display = 'none';
            dom.byId('header').style.display = 'none';
            dom.byId('footer').style.display =  'none';
            dojo.byId('mapDiv').style.width = "100%";
      dojo.byId('mapDiv').style.height = "100%";
            map.resize();
            map.reposition();
   dojo.byId("fullScreen").innerHTML = changeLabel;
html, body {
    height: 100%;
    width: 100%;
    margin: 0;
body {
    background-color: white;
    overflow: hidden;
    font-family:"Trebuchet MS";
#header {
    margin: 5px;
    border: solid 2px #224a54;
    height: 70px;
#leftPane {
    margin: 2px;
    padding: 2px;
    width: 20%;
#mapDiv {
    margin: 2px;
    -moz-border-radius: 4px;
#footer {
    margin: 2px;
    height: 40px;
#buttonDiv {
    position:absolute;
    right:40px;
    top:10px;
    z-Index:999;
by Anonymous User
Not applicable
Dear mariczone
this is my code
                </div>
                </div>
            </div>
        </div>
            </div>
        </div>
    </div>
</body>
var map;
require([
    "esri/map",
Map,
domConstruct) {
    parser.parse()
        basemap: "streets",
        zoom: 8
   if(inEdit == true){
   } else {
            map.resize();
            map.reposition();
html, body {
    height: 100%;
    width: 100%;
    margin: 0;
body {
    overflow: hidden;
#header {
    margin: 5px;
    height: 70px;
#leftPane {
    margin: 2px;
    padding: 2px;
    width: 20%;
#mapDiv {
    margin: 2px;
#footer {
    margin: 2px;
    height: 40px;
#buttonDiv {
    position:absolute;
    right:40px;
    top:10px;
    z-Index:999;
From your code. I fix only fullscreen method http://jsfiddle.net/7SY5q/12/ u need to set back method for restore old position.
and this is complete code for back method that I edit from "JSkinn3" example : http://jsfiddle.net/7SY5q/11/
xiaoyunnsongb
Dear mariczone�?
[ATTACH=CONFIG]33547[/ATTACH] this is  after click Back , How can it click it to before [ATTACH=CONFIG]33548[/ATTACH]
