How can i create a checkboxes TOC dynamic
1110
01-05-2024 05:47 PM
DiegoOspina
Hello guys, I need help, I must create a TOC of checkboxes with the following structure, a checkbox for the year, when I select the year, it displays 4 checkboxes, one for each quarter, and if I select a quarter, it must display 5 checkboxes that allow me to select the meteorological variable that I want to observe. Regarding the base map, I take the information by making a rest request to the service's json, which I would also like to know some suggestions on how I can manipulate it in such a way that I can work with it easily. The project is a viewer of meteorological variables, the TOC information must be added dynamically
Noah-Sager
Hi @DiegoOspina, thank you for posting here. These are great questions, but I think you would benefit from first going through one or more tutorials to get a feel for the JS SDK fundamentals:
https://developers.arcgis.com/javascript/latest/tutorials/change-the-basemap-style/
https://developers.arcgis.com/javascript/latest/tutorials/add-a-feature-layer/
And here is an example of our LayerList widget, which is similar to the TOC you described.
https://developers.arcgis.com/javascript/latest/sample-code/widgets-layerlist-actions/
