How can I add a button to the Editor dijit?
4980
02-01-2015 01:58 AM
MiriEshel
Hi all,
In the past, as far as I remember, the AttributInspector was a property of the Editor. I could reach it via : myEditor._attributeInspector.
Now the AttributInspector is a seperate widget.
I simply want to add a button besides the Delete button and use it in the webApp builder.
I prefer to make changes in the Edit widget than to write a new custom widget with the AttributeInspector dijit. I find it a little bit cumbersome.
I need it very urgently!
Thanks a  lot,
Miri Eshel
MiriEshel
My mistake, I found the attributeInspector property in the Editor but I will rephrase the question:
If I want to add a new OK button besides the Delete button, is it the best way to address the attributeInspector and change it? Is there another option?
Thanks a lot,
Miri
RobertScheitlin__GISP
Miri,
   This sample shows how to add a save button next to the delete button so I think that it is exactly what you are looking for.
Using the attribute inspector | ArcGIS API for JavaScript
MiriEshel
Hi Robert. Thanks. I used this sample as you can see from my oother question in ArcGIS for Javascript API.
There I will check the option of changing the CSS and let you know.
Thanks again,
Miri
StanMcShinsky
Miri,
Will you post the code you changed/added to get it to work? I think it would be very helpful to have this available so others dont have to try and redo what you are doing. Thanks.
