HomeButton not working with my webmap ID
1262
01-15-2014 05:22 AM
VirginieVauthrot
Hello everyone,
I'm searching to add a HomeButton in my API ArcGIS that uses a webmap. When I add the HomeButton in my code, this one appears on the map but isn't working (I can't come back in my default map).
Is HomeButton can be loaded with a webmap ID ?
Here is my code (in file attached) :
Noah-Sager
Hello Virginie, and welcome to Esri Forums!
It is possible to use the Home button with a webmap. I found a small syntax error in the code you posted, but here is a slightly modified version, see if it works for you.
-Noah
Noah-Sager
-Noah
VirginieVauthrot
It works for me !
Thanks a lot for your help Noah 🙂
