HitTest not returning aggregated CLUSTER graphics
944
06-27-2023 07:53 AM
michaelpoa
HitTest used to return cluster graphics with a clusterId. Then it's possible to query features for this cluster (only). Now the hitTest is returning all features even the ones below the cluster for example:
hitTest returning 6 graphics instead of 5. Is it possible to hitTest with clustered option?
Atleast the isAggregate property should be true?
Thanks In Advance
Gr
KristianEkenes
I'm not observing this behavior. If you think you're encountering a bug, you should reach out to Esri support with a repro/test case so they can vet it and log it into our system to fix it more promptly.
Here's the test case I tried that appeared to work: https://codepen.io/kekenes/pen/yLQMYPx?editors=100
KristianEkenes
