Highlight point layer from within an Infowindow
963
08-03-2010 04:58 AM
simonmiles
background -
i've created a infowindow that will tell me election based info on a polygon layer,
var title = attr.PD_NAME;
        var content = "<b>Constit. :</b> " + attr.CONSTIT
                   + "<br /><b>Polling station :</b> <br />" + attr.POL_STAT
                   + "<br /><b>Web info :</b> <a href=" + attr.WEB +" target=_blank ;'>"+ attr.PD_NAME+"</a>"
               + "<br /><b>Ward : </b> " + attr.WARD;
I was wondering if it was possible from within that infowindow to add some code where by I could click on the "Polling station" attribute and within the same api, the polling station point would be highlighted on the map?
KellyHutchins
Esri Notable Contributor
The Identify Task sample from the help, shows how to highlight a feature from an info window. http://help.arcgis.com/EN/webapi/javascript/arcgis/demos/identify/identify_drilldown.html
