Hide or cancel popup windows on measurement?
3700
12-21-2014 04:17 AM
EduardoDomínguez
I was wondering if someone could help me with this: I'd want to take measures without popup windows on clicking, only these popups should appear out of measuring.
This is my identify task:
map.on("load", mapReady);
        var parcelsURL = "http://sampleserver6.arcgisonline.com/arcgis/rest/services/USA/MapServer/";
        map.addLayer(new ArcGISDynamicMapServiceLayer(parcelsURL,
          { visible: false }));
        function mapReady () {
          map.on("click", executeIdentifyTask);
          //create identify tasks and setup parameters
          identifyTask = new IdentifyTask(parcelsURL);
          identifyParams = new IdentifyParameters();
          identifyParams.tolerance = 3;
          identifyParams.returnGeometry = true;
          identifyParams.layerIds = [2];
          identifyParams.layerOption = IdentifyParameters.LAYER_OPTION_ALL;
          identifyParams.width = map.width;
          identifyParams.height = map.height;
        function executeIdentifyTask (event) {
          identifyParams.geometry = event.mapPoint;
          identifyParams.mapExtent = map.extent;
          var deferred = identifyTask
            .execute(identifyParams)
            .addCallback(function (response) {
              // response is an array of identify result objects
              // Let's return an array of features.
              return arrayUtils.map(response, function (result) {
                var feature = result.feature;
                var layerName = result.layerName;
                feature.attributes.layerName = layerName;
                if (layerName === 'States') {
                  var taxParcelTemplate = new InfoTemplate("Estado: ${STATE_NAME}",
                    "Población: ${POP2000} personas<br/> Dens. Pob.: ${POP00_SQMI} pers./milla cuadr.<br/> Área: ${area} millas cuadradas ");
                  feature.setInfoTemplate(taxParcelTemplate);
                else if (layerName === 'Building Footprints') {
                  console.log(feature.attributes.STATE_NAME);
                  var buildingFootprintTemplate = new InfoTemplate("",
                    "Estado: ${STATE_NAME}");
                  feature.setInfoTemplate(buildingFootprintTemplate);
                return feature;
And my measure task:
function initt() {
        //This sample requires a proxy page to handle communications with the ArcGIS Server services. You will need to
        //replace the url below with the location of a proxy on your machine. See the 'Using the proxy page' help topic
        //for details on setting up a proxy page.
        esri.config.defaults.io.proxyUrl = "/proxy/";
        esri.config.defaults.io.alwaysUseProxy = false;
        //This service is for development and testing purposes only. We recommend that you create your own geometry service for use within your applications
        esri.config.defaults.geometryService = new esri.tasks.GeometryService("http://tasks.arcgisonline.com/ArcGIS/rest/services/Geometry/GeometryServer");
        dojo.connect(map, 'onLoad', function(map) {
      function initToolbar(mymap) {
        //define a new line symbol and point symbol to use for measure tools
        var pms = new esri.symbol.PictureMarkerSymbol("images/flag.png",24,24);
        pms.setOffset(9,11);
        var sls = new esri.symbol.SimpleLineSymbol(esri.symbol.SimpleLineSymbol.STYLE_DOT,
            new dojo.Color([255,0,0,0.55]), 4);
        var measurement = new esri.dijit.Measurement({
          map: mymap,
          lineSymbol:sls,
          pointSymbol:pms,
        }, dojo.byId('measurementDiv'));
        measurement.startup();
        measurement.setTool("area",true);
      dojo.ready(initt);
and the button action:
  on(dojo.byId("medidas"),"click",fmedidas);
        function fmedidas(){
         initToolbar(map);
Many thanks.
JakeSkinner
Esri Esteemed Contributor
Hi Eduardo,
Here is an example that demonstrates this.  When a measurement tool is selected, the map's click event to identify the features is disconnected  When the measurement is finished, the event is re-connected.
LuciHawkins
This is the code I use to halt the identify task if a measurement tool is active.  Hope it helps
Luci
var measureMode = dojo.query(".esriButton .dijitButtonNode").some(function(node, index, arr) {
if (node.childNodes[0].checked) {
//at least one of the measure tools is active so disable identify
return true;
if (!measureMode) {
EduardoDomínguez
Many thanks, problem solved!!.
