Hide measurement units
2776
11-20-2013 04:06 AM
Salomon_VágadalJoensen
How do I hide units in the measurement widget?
There doesn't seem to be a method in the JS API to hide a unit. As an added note, I know how to add units to the unitDictionary and add them into the location and area dropdown menus, but I don't know how to remove unwanted units from the menus.
BjornSvensson
Esri Alum
I think you're right, but I'm curious if you just want to hide the "non-metric" ones? (which I think is the most common scenario).
Or do you want even more fine-grained control?
Correct, I only want to hide the non-metric units.
I already have added Nautical Miles and Square Nautical Miles units as suggested in this" rel="nofollow" target="_blank">http://forums.arcgis.com/threads/81680-Nautical-Miles-Units-for... thread.
EDIT: Although, an added way to write which units are shown from the Measurement drop-down menu would be even better.
