Help with the height of the map and toolbar.
2052
06-18-2013 06:32 AM
YgorThomaz
Hello,
I am a C # programmer for years. Now I'm interested in front-end. I did the code below, but something seems wrong.
I wish the divMap use the height available dynamically. Use 100% and not another value as height: 96.5%;. If I use 100% it generates scrollbar or hide part of the map, I would avoid it.
/* [ 1. General ] */
html, body
 padding: 0;
 margin: 0;
 height: 100%;
 width: 100%;
body
 background-color: white;
 overflow: hidden;
/* [ 2. Map / #mapDiv ] */
#mapDiv
 height: 96.5%;
 margin: 0;
/* [ 3. Toolbar / #toolbar ] */
#toolbar
 text-align: center;
<body class="claro">
        <div id="toolbar" data-dojo-type="dijit/Toolbar">
            <button id="zoomin" type="button">
            </button>
            <button id="zoomout" type="button">
            </button>
        </div>
    <div id="mapDiv"></div>
    </div>
Thank you! (:
SteveCole
Honored Contributor
Set your height to 100% as desired but also add
overflow: hidden
to the CSS properties of #mapDiv. That should prevent the scrollbar from appearing.
BenFousek
1. Try using dijit/layout/BorderContainer with the toolbar as the top region and map as the center region. This is the best way to get a dynamically sized map.
2. Always use
#map { overflow:hidden; }
to remove scrollbars from map no matter what you do for layout.
JeffJacobson
I encountered a similar problem yesterday mixing ArcGIS JS with Twitter Bootstrap. What I did was manually resize the map when the browser window changed.
/*global require*/
/*jslint browser:true*/
require(["dojo/on", "esri/map"], function (on, Map) {
 "use strict";
 var map;
 // Create the map.
 /** Set the height of the map div.
 function setMapDivHeight() {
  var topNavBar, mapDiv, desiredHeight;
  topNavBar = document.getElementById("topNavBar");
  mapDiv = document.getElementById("map");
  desiredHeight = window.innerHeight - topNavBar.clientHeight - 40;
  mapDiv.style.height = [desiredHeight, "px"].join("");
  if (map) {
   map.resize();
 setMapDivHeight();
 map = new Map("map", {
  basemap: "streets",
  autoResize: false
 on.once(map, "load", function () {
  on(window, "resize", setMapDivHeight);
YgorThomaz
Jeff,
I also thought about using the "Twitter Bootstrap". But I would add many resources without using them.
I am analyzing your file default.js very interesting.
Thank you!
