Help with Sketch Widget Tooltip Units
1367
05-15-2024 07:25 AM
FlockSafety
I would like to change the units displayed on the Sketch widget tooltip from meters to miles. I combed through the documentation and couldn't find any way to configure this. Our application stores the distance and area (plus the units) in miles, but we are having trouble displaying the built-in measurement while drawing in miles.
The tooltip in the screenshot is displayed using the "tooltipOptions={{ enabled: true }}" parameter for the Sketch Widget
The only alternative I found was to make a TextSymbol located at the centroid lat/lng of the polygon. But this felt clunky to implement given there is already a dynamic tooltip in the SDK.
AlexQuintero1
I am running into the same issue. Doesn't appear that it can be changed.
Katie_Clark
MVP Regular Contributor
I was able to accomplish this by explicitly setting the valueOptions > displayUnits property for the Sketch class. Here's an example of how I'm using it:
const sketchWidget = new Sketch({
      layer: sketchLayer,
      view: view,
      viewModel: sketchViewModel,
      valueOptions: {
        displayUnits: {
          length: "feet",
          area: "acres"
      visibleElements: {
        duplicateButton: false,
        createTools: {
          point: geometryTypes.includes("point"),
          polyline: geometryTypes.includes("polyline"),
          polygon: geometryTypes.includes("polygon"),
          rectangle: false,
          circle: false
      defaultUpdateOptions: {
        reshapeOptions: {
          shapeOperation: "none"
        enableRotation: false,
        enableScaling: false,
        enableZ: false,
        highlightOptions: {
          enabled: false
        tool: "reshape"
      creationMode: "update"
Here's a link to the documentation - it says it's in beta so perhaps this feature wasn't available when this post was originally made. It's supported since ArcGIS Maps SDK for JavaScript 4.29.
Hope this helps if someone comes across this post in the future!
Best,
Katie
If this post helped you, please consider giving a kudos and/or marking as the accepted solution. Thanks!
