Help with Legend Widget
1941
6
10-21-2013 10:20 AM
RobertHupp
I am new to the Javascript API, but have been able to put together this map from examples and forums and it all works fine except for when I try to add a Legend. Can someone please help get the legend to display?
Here is my code:
<html>
  <head>
    <meta http-equiv="Content-Type" content="text/html; charset=utf-8">
    <meta http-equiv="X-UA-Compatible" content="IE=7, IE=9, IE=10">
    <!--The viewport meta tag is used to improve the presentation and behavior of the samples
      on iOS devices-->
    <meta name="viewport" content="initial-scale=1, maximum-scale=1,user-scalable=no">
    <title>San Antonio 1896 Points of  Interest</title>
    <link rel="stylesheet" href="http://js.arcgis.com/3.7/js/dojo/dijit/themes/claro/claro.css">
    <link rel="stylesheet" href="http://js.arcgis.com/3.7/js/dojo/dojox/grid/resources/Grid.css">
    <link rel="stylesheet" href="http://js.arcgis.com/3.7/js/dojo/dojox/grid/resources/claroGrid.css">
    <link rel="stylesheet" href="http://js.arcgis.com/3.7/js/esri/css/esri.css">
    <style>
      html, body { height: 100%; width: 100%; margin: 0; padding: 0; }
    </style>
    <script>var dojoConfig = { parseOnLoad:true }</script>
    <script src="http://js.arcgis.com/3.7/"></script>
    <script>
      dojo.require("esri.map");
      dojo.require("dojox.grid.DataGrid");
      dojo.require("dojo.data.ItemFileReadStore");
      dojo.require("esri.tasks.find");
      dojo.require("dijit.layout.BorderContainer");
      dojo.require("dijit.layout.ContentPane");
      dojo.require("dijit.form.Button");
   dojo.require("esri.dijit.Legend");
      var findTask, findParams;
      var map, center, zoom;
      var grid, store;
      function init() {
        dojo.connect(grid, "onRowClick", onRowClickHandler);
        center = [-98.544, 29.47];
        zoom = 11;
        map = new esri.Map("map", {
          basemap: "hybrid",
          center: center,
          zoom: zoom
  var transMapLayer = new esri.layers.ArcGISDynamicMapServiceLayer("http://server.arcgisonline.com/ArcGIS/rest/services/Reference/World_Transportation/MapServer", {
        map.addLayer(transMapLayer);
  var mainMapLayer = new esri.layers.ArcGISDynamicMapServiceLayer("http://mapservices2.bexar.org/arcgis/rest/services/Historic/Historic_POI/MapServer", {
        map.addLayer(mainMapLayer);
        //Create Find Task using the URL of the map service to search
        findTask = new esri.tasks.FindTask("http://mapservices2.bexar.org/arcgis/rest/services/Historic/Historic_POI/MapServer");
        dojo.connect(map, "onLoad", function() {
          //Create the find parameters
          findParams = new esri.tasks.FindParameters();
          findParams.returnGeometry = true;
          findParams.layerIds = [0];
          findParams.searchFields = [ "Name", "Owner", "Category"];
          findParams.outSpatialReference = map.spatialReference;
          console.log("find sr: ", findParams.outSpatialReference);
   dojo.connect(map, "onLayersAddResult", function(results) {
  var legend = new esri.dijit.Legend({
   map:map,
   layerInfos:[{layer:mainMapLayer,title:"1896"}],
   arrangement:esri.dijit.Legend.ALIGN_RIGHT
   },"legendDiv");
   legend.startup();
      function doFind() {
        //Set the search text to the value in the box
        findParams.searchText = dojo.byId("ownerName").value;
        findTask.execute(findParams,showResults);
      function showResults(results) {
        //This function works with an array of FindResult that the task returns
        map.graphics.clear();
        var symbol =  new esri.symbol.SimpleMarkerSymbol(esri.symbol.SimpleMarkerSymbol.STYLE_SQUARE, 25, new esri.symbol.SimpleLineSymbol(esri.symbol.SimpleLineSymbol.STYLE_SOLID, new dojo.Color([255, 0, 0]), 1), new dojo.Color([0, 255, 0, 0.25]));
        //create array of attributes
        var items = dojo.map(results,function(result){
          var graphic = result.feature;
          graphic.setSymbol(symbol);
          map.graphics.add(graphic);
          return result.feature.attributes;
        //Create data object to be used in store
        var data = {
          identifier: "OBJECTID",  //This field needs to have unique values
          label: "OBJECTID", //Name field for display. Not pertinent to a grid but may be used elsewhere.
          items: items
         //Create data store and bind to grid.
        store = new dojo.data.ItemFileReadStore({ data:data });
        var grid = dijit.byId('grid');
        grid.setStore(store);
        //Zoom back to the initial map extent
        map.centerAndZoom(center, zoom);
      //Zoom to the parcel when the user clicks a row
      function onRowClickHandler(evt){
        var clickedTaxLotId = grid.getItem(evt.rowIndex).OBJECTID;
        var selectedTaxLot;
  var distance = 100;
        dojo.forEach(map.graphics.graphics,function(graphic){
          if((graphic.attributes) && graphic.attributes.OBJECTID === clickedTaxLotId){
            selectedTaxLot = graphic.geometry;
            return;
  var newExtent = new esri.geometry.Extent({
        "xmin": selectedTaxLot.x - distance,
        "ymin": selectedTaxLot.y - distance,
        "xmax": selectedTaxLot.x + distance,
        "ymax": selectedTaxLot.y + distance,
        "spatialReference": {
            "wkid": 102100
        map.setExtent(newExtent);
  console.log(map.graphics.graphics);
      dojo.ready(init);
    </script>
  </head>
  <body class="claro">
  <div data-dojo-type="dijit.layout.BorderContainer" data-dojo-props="design:'headline'"  style="width:100%;height:100%;margin:0;">
    <div data-dojo-type="dijit.layout.ContentPane" data-dojo-props="region:'top'" style="height:40px;">
      Point of Interest: <input type="text" id="ownerName" size="20" value="Koehler" />
      <button data-dojo-type="dijit.form.Button"  data-dojo-props='onClick:function(){ doFind();}, value:"Search"'>
        Search
      </button>
    </div>
<div data-dojo-props="region:'left'" data-dojo-type="dijit.layout.ContentPane" data-dojo-props="title:'Legend'" style="border:1px solid #000;">
<div id="legendDiv"></div>
</div>
    <div id="map" data-dojo-props="region:'center'" data-dojo-type="dijit.layout.ContentPane" style="border:1px solid #000;"></div>
    <div data-dojo-type="dijit.layout.ContentPane" data-dojo-props="region:'bottom'" style="height:150px;">
     <table data-dojo-type="dojox.grid.DataGrid" data-dojo-id="grid"  id="grid" data-dojo-props="rowsPerPage:'5', rowSelector:'20px'">
      <thead>
        <tr>
          <th field="Name" width="50%">Point of Interest</th>
          <th field="Category">Category</th>
    <th field="Owner">Owner</th>
        </tr>
      </thead>
    </table>
    </div>
  </div>
  </body>
</html>
RobertHupp
The problem in your code is with the map.onLayersAddResult event, since your legend is created inside the callback of this event. This event is fired when map.addLayers(<an array of layers>) is executed. map.addLayer() will NOT fire this event.
The only thing you need to do is to change:
map.addLayer(transMapLayer);  ... map.addLayer(mainMapLayer);
to:
map.addLayers([transMapLayer, mainMapLayer]);
You may need to tweak your CSS styles a bit to adjust the layout afterward.
Makes perfect sense, but when I add that code it still doesn't fire. ???
JanelYang
to:
RobertHupp
to:
JanelYang
Here is a couple of things to can check:
1. Make sure map.onLayersAddResult is fired.
2. Adjust your layout. You can set a width for the legend div to make sure there is space for legend when it is started.
<div data-dojo-props="region:'left'" data-dojo-type="dijit.layout.ContentPane" data-dojo-props="title:'Legend'" style="border:1px solid #000; width: 200px">
RobertHupp
Perfect, works like a charm, Thanks so much Jerome. Now only if I knew a quick way to have the pop-ups for my POI layer show on the map, any ideas would be greatly appreciated.
    <script>
      var grid, store;
      function init() {
        zoom = 11;
          basemap: "hybrid",
          center: center,
          zoom: zoom
   dojo.connect(map, "onLayersAddResult", function(result) {
   map:map,
   layerInfos:[{layer:mainMapLayer,title:"San Antonio Points of Interest 1896"}],
   },"legendDiv");
   legend.startup();
      function doFind() {
        var data = {
          items: items
        var selectedTaxLot;
  var distance = 100;
            return;
            "wkid": 102100
      dojo.ready(init);
    </script>
  </head>
        Search
      </button>
    </div>
 <div data-dojo-props="region:'left'" data-dojo-type="dijit.layout.ContentPane" data-dojo-props="title:'Legend'" style="width:18%; border:1px solid #000;">
 </div>
      <thead>
        <tr>
        </tr>
      </thead>
    </table>
    </div>
  </div>
  </body>
</html>
JanelYang
A simple way to do this with your existing code is to set InfoTemplate for the graphic in your showResults(results) function:
graphic.setInfoTemplate(new esri.InfoTemplate());
You can further customized the text in your pop-ups. Refer to Graphic.setInfoTemplate(infoTemplate) for more information.
RobertHupp
It shows the info window for the search results of the layer but not the non returned results. How can I get a pop up for all the items in the mainMapLayer when clicked on?
