Help! Unable to add webmap
1020
12-17-2019 03:22 PM
ChrisSnow
Trying to add a webmap but even in the sandbox I get
Fetch API cannot load https://tileservice.charts.noaa.gov/tiles/wmts/1.0.0/WMTSCapabilities.xml due to access control checks.
Origin xxx is not allowed by Access-Control-Allow-Origin
var webmap = new WebMap({
portalItem: {
Any suggestions?
Noah-Sager
It looks like the 4x API is a bit more strict with cors and ssl than the 3x version (which is why I think it displays in the 3x based AGO Map Viewer). If you add a proxy to the mix, the wmts webmap displays fine.
Resources:
CORS with the API | ArcGIS API for JavaScript 4.14
GitHub - Esri/resource-proxy: Proxy files for DotNet, Java and PHP.
https://codepen.io/noash/pen/BayWZKv  (codepen does not run, but if you supply a link to your proxy and run locally, it will work)
