help me to fix the Intellisense error
3180
10-10-2013 10:26 PM
PhuongNguyen_Thanh
Hi all !
I download the code plugin to do web map project in here : https://developers.arcgis.com/en/javascript/jsapi/api_codeassist.html
. I do all the steps. But it shows me that problem 😞
[ATTACH=CONFIG]28252[/ATTACH]
Please help me 😞
Best Regards,
Phuong Nguyen
ManishkumarPatel
Hi all !
Please help me 😞
Best Regards,
Phuong Nguyen
Hi Phuong,
Did you  add a <script> tag that references to the code assist document.
      <script type="text/javascript" src="path_to_the_code_assist_document"></script>
Thats should do the trick. I just tried that at my end and it works fine.
[ATTACH=CONFIG]0[/ATTACH]
Let me know the results.
[ATTACH=CONFIG]28253[/ATTACH]
Thanks & Regards,
Manish
PhuongNguyen_Thanh
Hi Phuong,
Thanks & Regards,
Manish
Hi Manish,
I already added this script to my file but it's still not working
Here's my pic[ATTACH=CONFIG]28262[/ATTACH]
Here's my location file
[ATTACH=CONFIG]28263[/ATTACH]
Best Regards,
Phuong Nguyen
PhuongNguyen_Thanh
up for help 😞
JonathanUihlein
It looks like you're trying to code in AMD style (which is preferred and the best way to go about writing an application using the ESRI JSAPI).
On the Intellisense page you linked:
Note: As of v3.6, coding in AMD style is not supported yet.
I wouldn't worry about using the plugin until it is updated.
PhuongNguyen_Thanh
Thank you Jon.Uihlein ! I got it
