Help!! How to add elevation service to script...
1125
12-07-2011 03:18 PM
MatthewLopez
Hello all,
I'm trying to add the Elevation service to my script. Does anybody know how?
Elevation Service URL: http://sampleserver2.arcgisonline.com/ArcGIS/rest/services/Elevation
<!DOCTYPE HTML PUBLIC "-//W3C//DTD HTML 4.01//EN" "http://www.w3.org/TR/html4/strict.dtd">
<html>
  <head>
    <meta http-equiv="X-UA-Compatible" content="IE=7,IE=9" />
    <!--The viewport meta tag is used to improve the presentation and behavior
    of the samples on iOS devices-->
    <meta name="viewport" content="initial-scale=1, maximum-scale=1,user-scalable=no"
    <title>
    </title>
    <link rel="stylesheet" type="text/css" href="http://serverapi.arcgisonline.com/jsapi/arcgis/2.5/js/dojo/dijit/themes/claro/claro.css">
    <style type="text/css">
      html, body { height: 100%; width: 100%; margin: 0; padding: 0; } #map{
      padding:0; }
    </style>
    <script type="text/javascript">
    var djConfig = {
  parseOnLoad: true
    </script>
    <script type="text/javascript" src="http://serverapi.arcgisonline.com/jsapi/arcgis/?v=2.5">
    </script>
    dojo.require("dijit.dijit"); // optimize: load dijit layer
    dojo.require("dijit.layout.BorderContainer");
    dojo.require("dijit.layout.ContentPane");
    dojo.require("esri.map");
    dojo.require("esri.virtualearth.VETiledLayer");
    dojo.require("dijit.TitlePane");
    dojo.require("esri.dijit.BasemapGallery");
    dojo.require("esri.arcgis.utils");
    dojo.require("esri.dijit.Legend");
    var map = null;
    function init() {
      var initExtent = new esri.geometry.Extent({
        "xmin": -11209999,
        "ymin": 3481772,
        "xmax": -10668897,
        "ymax": 3369459,
        "spatialReference": {
          "wkid": 102100
      map = new esri.Map("map", {
        extent: initExtent
      var initBasemap = new esri.layers.ArcGISTiledMapServiceLayer("http://server.arcgisonline.com/ArcGIS/rest/services/World_Topo_Map/MapServer");
      map.addLayer(initBasemap);
      var operationalLayer = new esri.layers.ArcGISDynamicMapServiceLayer("https://gis.sanantonio.gov/ArcGIS/rest/services/BikeFacilities/MapServer");
      map.addLayers([operationalLayer]);
      //add the legend
      dojo.connect(map, 'onLayersAddResult', function(results) {
        console.log("on layers add result: ", results);
        var layerInfo = dojo.map(results, function(layer, index) {
          return {
            layer: layer.layer,
            // title: layer.layer.name // name property is undefined...
            title: "Bike Facilities"
        if (layerInfo.length > 0) {
          var legendDijit = new esri.dijit.Legend({
            map: map,
            layerInfos: layerInfo
          }, "legendDiv");
          legendDijit.startup();
      createBasemapGallery();
      //resize the map when the browser resizes
      dojo.connect(dijit.byId('map'), 'resize', map, map.resize);
    function createBasemapGallery() {
      //add the basemap gallery, in this case we'll display maps from ArcGIS.com including bing maps
      var basemapGallery = new esri.dijit.BasemapGallery({
        showArcGISBasemaps: true,
        bingMapsKey: 'A1GXEbIE8xrnP3IbNrLVIqRfH1FLjVX53xuqCMqM2Y1Cvp_ugYoFdPn-Sn2XyX9Q',
        map: map
      }, "basemapGallery");
      basemapGallery.startup();
      dojo.connect(basemapGallery, "onError", function(msg) {
        console.log(msg)
    //show map on load
    dojo.addOnLoad(init);
    </script>
  </head>
  <body class="claro">
    <div dojotype="dijit.layout.BorderContainer" design="headline" gutters="false"
    style="width:100%;height:100%;margin:0;">
      <div id="leftPane" class="roundedCorners" dojotype="dijit.layout.ContentPane"
      region="left" style="width:275px;">
        Legend
        <div id="legendDiv"></div>
      </div>
      <div id="map" dojotype="dijit.layout.ContentPane" region="center" style="border:1px solid #000;padding:0;">
        <div style="position:absolute; right:20px; top:10px; z-Index:999;">
          <div dojoType="dijit.TitlePane" title="Switch Basemap" closable="false"
          open="false">
            <div dojoType="dijit.layout.ContentPane" style="width:380px; height:280px; overflow:auto;">
              <div id="basemapGallery">
              </div>
            </div>
          </div>
        </div>
      </div>
    </div>
  </body>
</html>
StephenLead
Honored Contributor
Hi Matthew,
That's a geoprocessing service, to try looking at some geoprocessing samples or the Geoprocessor Task help reference.
(By the way, the easiest way to paste code is to use the # icon above, rather than using * characters to space it out.)
Cheers,
Steve
