Help! How can I measure the distance between points
4807
6
08-20-2010 01:45 PM
AlejandroMorales
Hi, everyone
I'm having this problem, I have 2 layers let's say I have this situation:
Layer A:
Point1
Point2
Point3
Point4
Layer B:
Point1
Point2
Point3
Point4
The Points of the two layers are related this way:
A.Point1 connected to B.Point1
A.Point2 connected to B.Point2
A.Point3 connected to B.Point3
A.Point4 connected to B.Point4
How can I measure their distance between each other using the JavaScript API , If each point is in a different layer.
Please If you have some code I can use I will thank you so much!
Alex
RahulRavikumar
If all you care about is the distance, then you can get the coordinates of the points for which you need to measure distances; and pass them to the geometry service's "lengths" operation.
AlejandroMorales
Thanks for your response,
How can I do that? Can you give some code please?
Thank you.
AlejandroMorales
Thanks for the help guys! I really appreciate but
what I'm trying to do is to measure the distance between 2 points that already have X and Y coordinates so
Point A (Layer 1) has all its properties including X and Y
Point B (Layer 2) same as Point B
is there a procedure, function where I can get the distance between A and B ?
TimRourke
Alex,
I think if you take a close look at the first page swingley pointed out (http://help.arcgis.com/en/webapi/javascript/arcgis/help/jssamples_start.htm#jssamples/util_distance....), you'll see some code that shows how to set up the parameters for a call to the GeometryService's distance task. It shows how to add geometries from an array. In your case, you'd add your two known points:
var distParams = new esri.tasks.DistanceParameters();
distParams.distanceUnit = esri.tasks.GeometryService.UNIT_STATUTE_MILE;
distParams.geometry1 = pointA;     //<--- your Point A geometry
distParams.geometry2 = pointB;     //<--- your Point B geometry
distParams.geodesic = true;
The sample code on the page shows how to call GeometryService.distance and work with its results. The section where it says function(distance){..}) catches the data returned by GeometryService.distance in the parameter distance.
geometryService.distance(distParams, function(distance) {
     // Do what you want with the result.
Hope that helps,
Tim
AlejandroMorales
Tim, thank you so much!, I'm trying it right now I just have one question, when I create the points I use this lines (just to try) :
p1 = new esri.geometry.Geometry.Point(767045.94,1620609.96,??);
p2 = new esri.geometry.Geometry.Point(768450.94,7621609.90,??);
I don't know what to put in the spatial reference parameter because my map has this as a spatial reference:
PROJCS["WGS_1984_UTM_Zone_15N",GEOGCS["GCS_WGS_1984",DATUM["D_WGS_1984",SPHEROID["WGS_1984",6378137.0,298.257223563]],PRIMEM["Greenwich",0.0],UNIT["Degree",0.0174532925199433]],PROJECTION["Transverse_Mercator"],PARAMETER["False_Easting",500.0],PARAMETER["False_Northing",0.0],PARAMETER["Central_Meridian",-93.0],PARAMETER["Scale_Factor",0.9996],PARAMETER["Latitude_Of_Origin",0.0],UNIT["Kilometer",1000.0]]
It's a lot and I don't think i have to put all that into a parameter right?
Please can You tell me, what should I do?
Thanks
Alex,
Alex,
Hope that helps,
Tim
