Hello. I am using the swap web maps in the same view. I want to create a legend for the web maps in the api. Is that possible yet?
2498
6
06-19-2017 12:41 PM
BrandonPrice
Thanks in advance.
ChristopherSchreiber
Yes,
Here is an example using your html file.
<!DOCTYPE html>
<html>
<head>
  <meta charset="utf-8">
  <meta name="viewport" content="initial-scale=1,maximum-scale=1,user-scalable=no">
  <title>Underground Utilities Caltrans District 7</title>
  <style>
    html,
    body {
      font-family: sans-serif;
      padding: 0;
      margin: 0;
      height: 100%;
      width: 100%;
      overflow: hidden;
       color: white;
       text-align: center;
    #viewDiv {
      position: absolute;
      right: 0;
      left: 0;
      top: 0;
      bottom: 60px;
    #viewy {
      position: absolute;
      width: 1150px;
      height: 40px;
      left: 10%;
       text-align: justify;
       z-index: 1;
       text-align: center;
       -webkit-text-stroke-width: 1.2px;
      -webkit-text-stroke-color: black;
       font-size: 35px
    .footer {
      position: absolute;
      bottom: 0;
      width: 100%;
      height: 60px;
    .btns {
      margin: 0 auto;
      display: flex;
      flex-direction: row;
      justify-content: center;
      align-items: center;
      overflow: auto;
    .btn-switch {
      flex-grow: 4;
      background-color: #54A0CD;
      color: #FFF;
      margin: 1px;
      width: 50%;
      padding: 20px;
      overflow: auto;
      text-align: center;
      cursor: pointer;
      font-size: 0.7em;
    .active-map {
      color: #fff;
      background-color: #54CDB4;
  </style>
  <link rel="stylesheet" href="https://js.arcgis.com/4.3/esri/css/main.css">
  <script src="https://js.arcgis.com/4.3/"></script>
  <script>
    require([
       "dojo/dom-construct",
      "esri/views/MapView",
       "esri/widgets/Legend",
      "esri/WebMap",
       "esri/widgets/Search",
      "dojo/on",
      "dojo/domReady!"
    ], function(
      domConstruct, MapView, Legend, WebMap, Search,
      on
      var webmapids = [
        "ba7b97b7d6b24c6381eba23062f8aab1",
        "7884594fbc904ac6bdb540727ff2f5d7",
        "bde977a8dcb34a719a1b0bc30df9542d",
          "e857341735434b67ae844244ae4701ca",
          "4818da5fb8de4fafaa5499b4873c1bd7",
       * Create multiple WebMap instances
      var webmaps = webmapids.map(function(webmapid) {
        return new WebMap({
          portalItem: {
       * Initialize the View with the first WebMap
      var view = new MapView({
        map: webmaps[0],
        container: "viewDiv"
      on(document.querySelector(".btns"), ".btn-switch:click", function(
        event) {
         * On a button click, change the map of the View
        var id = event.target.getAttribute("data-id");
        if (id) {
          var webmap = webmaps[id];
          view.map = webmap;
          var nodes = document.querySelectorAll(".btn-switch");
          for (var idx = 0; idx < nodes.length; idx++) {
            var node = nodes[idx];
            var mapIndex = node.getAttribute("data-id");
            if (mapIndex === id) {
              node.classList.add("active-map");
            } else {
              node.classList.remove("active-map");
//******************* MY EDIT: ADD LEGEND HERE ***************************//
      var legend = new Legend({
          view: view
//************************************** END MY EDITS ******************//
        var logo = domConstruct.create("img", {
        src: "https://onramp.dot.ca.gov/hq/paffairs/CT_No_Logotype/CT_logo_no_type.gif",
          style: "height:50px;width:80px;",
        title: "Office of Surveys, Geospatial Unit"
       var search = new Search({
        view: view
       view.ui.add(logo, "bottom-right");
       view.ui.add(search, "top-right");
       view.ui.add(legend, "top-right");
  </script>
</head>
<body>
  <section class="footer">
    <div class="btns">
      <div class="btn-switch active-map" data-id="0">Caltrans Utilities</div>
      <div class="btn-switch" data-id="1">Electrical</div>
      <div class="btn-switch" data-id="2">Natural Gas</div>
       <div class="btn-switch" data-id="3">Wastewater</div>
       <div class="btn-switch" data-id="4">Water</div>
       <div class="btn-switch" data-id="5">Utility Listing</div>
    </div>
  </section>
  <div id="viewy"><b>Underground Utilities within Caltrans District 7<b></div>
  <div id="viewDiv"></div>
</body>
</html>‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍
The styling is not the greatest, so you may want to fancy it up!
But it does work!
Chris
ThomasSolow
BrandonPrice
This says it is not possible yet in the known limitations.
ThomasSolow
Which part isn't possible?
BrandonPrice
Thanks for the help. It works. Easier than what I thought. ☺
No problem!
Happy to help!
Don't forget to mark this question as "Answered"
Yes,
<!DOCTYPE html>
<html>
<head>
  <style>
    html,
    body {
      padding: 0;
      margin: 0;
      height: 100%;
      width: 100%;
      overflow: hidden;
       color: white;
       text-align: center;
    #viewDiv {
      position: absolute;
      right: 0;
      left: 0;
      top: 0;
      bottom: 60px;
    #viewy {
      position: absolute;
      width: 1150px;
      height: 40px;
      left: 10%;
       z-index: 1;
       text-align: center;
       font-size: 35px
    .footer {
      position: absolute;
      bottom: 0;
      width: 100%;
      height: 60px;
    .btns {
      margin: 0 auto;
      display: flex;
      overflow: auto;
    .btn-switch {
      flex-grow: 4;
      color: #FFF;
      margin: 1px;
      width: 50%;
      padding: 20px;
      overflow: auto;
      text-align: center;
      cursor: pointer;
      font-size: 0.7em;
    .active-map {
      color: #fff;
  </style>
  <script>
    require([
      "esri/WebMap",
      "dojo/on",
      "dojo/domReady!"
    ], function(
      on
      var webmapids = [
        return new WebMap({
          portalItem: {
        map: webmaps[0],
        event) {
        if (id) {
          view.map = webmap;
            } else {
          view: view
        view: view
  </script>
</head>
<body>
    <div class="btns">
    </div>
  </section>
</body>
But it does work!
Chris
