Heatmaps - How to reference all the data, not just the view
1497
07-15-2024 10:16 AM
AndrewMurdoch1
Good Day
I have a large network that I want to view as a heatmap.   I have the following heatmap render settings:
const heatmapParams = {
    layer: layer,
    view: view,
    field: field,
    colorStops: this.colourStops,
heatmapRendererCreator.createRenderer(heatmapParams).then((response) => {
    this.heatmapRenderSetting = response.renderer.clone();
    r(this.heatmapRenderSetting)
}).catch((error) => {
    console.log('Error');
    console.log(error);
    j(error);
If I'm zoomed out and view the data, the heatmap looks great, the problem, if I load the map being zoomed in with no data in the view, the heatmap is completely washed out.    Is there a way to generate the heat map using the data in the map view, what's in the current view extent?  Or, can I set the zoom dynamically before loading the Heatmap, so the data is in the view?
Thanks
AndrewMurdoch1
Good Afternoon
Thanks for the suggestion, but I don't think that works with a dynamic renderer.  I found a way to get the view to zoom to the layer extent, but now when zooming in everything goes too far the other way and disappears.
Thanks
KristianEkenes
This is how this method works. It only takes into account what is in the view.
That's because there is no data in the view. You will only see anything meaningful if you zoom to the area where you have data and want to create a heatmap.
Yes. You can set this with the goTo method or by setting the view extent.
AndrewMurdoch1
Good Day
Thanks for the reply, I ended up calling goTo() to "zoom out", which allows the data to render properly.
Thanks
