Having an issue with javascript Search Widget
4395
07-29-2015 10:37 AM
deleted-user-T42XKeMY9oXS
I am having an issue with the search widget. I have a web page that mixes the Editor widget and Search Widget. The symptom is that upon searching my feature layer, the map does zoom to the feature I was searching, but the infoWindow does not pop up upon clicking it. I can use the editor toolbar to add that (search result feature) to select it; but I want it to be preselected. I DO NOT WANT to use the search infowindow but the editor infowindow. I had thought this would be a very common requirement (so search a feature prior to editing it).
Here is my code:
<!DOCTYPE html>
<html>
<head>
    <meta http-equiv="Content-Type" content="text/html; charset=utf-8">
    <!--The viewport meta tag is used to improve the presentation and behavior of the samples
      on iOS devices-->
    <meta name="viewport" content="initial-scale=1, maximum-scale=1,user-scalable=no">
    <title>Edit Irrigation Data</title>
    <link rel="stylesheet" href="http://js.arcgis.com/3.14/dijit/themes/claro/claro.css">
    <link rel="stylesheet" href="http://js.arcgis.com/3.14/esri/css/esri.css" />
    <style>
        html, body {
            height: 100%;
            width: 100%;
            margin: 0;
            overflow: hidden;
        #map {
            padding: 0;
        #header {
            font-size: 1.1em;
            font-family: sans-serif;
            padding-left: 1em;
            padding-top: 4px;
            color: #660000;
        .templatePicker {
            border: none;
        .dj_ie .infowindow .window .top .right .user .content {
            position: relative;
        .dj_ie .simpleInfoWindow .content {
            position: relative;
        .dijitButton .dijitButtonNode, #drawingWrapper, #printButton {
            width: 160px;
        .esriPrint {
            padding: 0;
        label {
            display: inline-block;
            padding: 5px 5px 0 5px;
            font-weight: 400;
            font-size: 12pt;
    </style>
    <script src="http://js.arcgis.com/3.14/"></script>
    <script>
        var map;
        var app = {};
        app.map = null; app.toolbar = null; app.tool = null; app.symbols = null; app.printer = null;
        require([
          "esri/map", "esri/toolbars/draw", "esri/dijit/Print",
          "esri/tasks/GeometryService",
          "esri/toolbars/edit",
          "esri/layers/ArcGISTiledMapServiceLayer",
          "esri/layers/FeatureLayer",
          "esri/layers/LayerDrawingOptions",
          "esri/Color",
          "esri/geometry/Extent",
          "esri/SpatialReference",
          "esri/symbols/SimpleMarkerSymbol",
          "esri/symbols/SimpleLineSymbol", "esri/graphic",
          "esri/symbols/SimpleFillSymbol",
          "esri/dijit/editing/Editor",
          "esri/dijit/editing/TemplatePicker",
          "esri/dijit/LayerList",
          "esri/dijit/Search",
          "esri/tasks/query",
          "esri/InfoTemplate",
          "esri/config",
          "dojo/i18n!esri/nls/jsapi",
          "dojo/_base/array", "dojo/parser", "dojo/keys",
          "dojo/query", "dojo/dom", "dojo/dom-construct",
          "dijit/form/CheckBox", "dijit/form/Button",
          "dijit/layout/BorderContainer", "dijit/layout/ContentPane",
          "dojo/domReady!"
        ], function (
          Map, Draw, Print, GeometryService, Edit,
          ArcGISTiledMapServiceLayer, FeatureLayer,LayerDrawingOptions,
          Color, Extent, SpatialReference, SimpleMarkerSymbol, SimpleLineSymbol, Graphic, SimpleFillSymbol,
          Editor, TemplatePicker,LayerList, Search, Query, InfoTemplate,
          esriConfig, jsapiBundle,
          arrayUtils, parser, keys,
          query, dom, domConstruct,
          CheckBox, Button
            parser.parse();
            // snapping is enabled for this sample - change the tooltip to reflect this
            jsapiBundle.toolbars.draw.start = jsapiBundle.toolbars.draw.start + "<br>Press <b>ALT</b> to enable snapping";
            // refer to "Using the Proxy Page" for more information:  https://developers.arcgis.com/javascript/jshelp/ags_proxy.html
            //esriConfig.defaults.io.proxyUrl = "/proxy/";
            esriConfig.defaults.io.corsEnabledServers.push("static.arcgis.com");
            esriConfig.defaults.io.corsEnabledServers.push("services.arcgisonline.com");
            esriConfig.defaults.io.corsEnabledServers.push("gisweb");
            esriConfig.defaults.geometryService = new GeometryService("http://gisweb/arcgis/rest/services/Utilities/Geometry/GeometryServer");
            app.map = new Map("map", {
                basemap: "streets",
                center: [-120.84, 37.49],
                zoom: 14,
                slider: false
            app.map.on("load", function () {
                app.toolbar = new Draw(app.map);
                app.toolbar.on("draw-end", addToMap);
            app.printer = new Print({
                map: app.map,
                url: "http://gisweb/arcgis/rest/services/Utilities/PrintingTools/GPServer/Export%20Web%20Map%20Task"
            }, dom.byId("printButton"));
            app.printer.startup();
            app.symbols = {};
            app.symbols.point = new SimpleMarkerSymbol("square", 10, new SimpleLineSymbol(), new Color([0, 255, 0, 0.75]));
            app.symbols.polyline = new SimpleLineSymbol("solid", new Color([255, 128, 0]), 2);
            app.symbols.polygon = new SimpleFillSymbol().setColor(new Color([255, 255, 0, 0.25]));
            app.symbols.circle = new SimpleFillSymbol().setColor(new Color([0, 0, 180, 0.25]));
            query(".drawing").forEach(function (btn) {
                var button = new Button({
                    label: btn.innerHTML,
                    onClick: function () {
                        activateTool(this.id);
                }, btn);
            function activateTool(type) {
                app.tool = type.replace("freehand", "");
                app.toolbar.activate(type);
                app.map.hideZoomSlider();
            function addToMap(evt) {
                app.toolbar.deactivate();
                app.map.showZoomSlider();
                var graphic = new Graphic(evt.geometry, app.symbols[app.tool]);
                app.map.graphics.add(graphic);
            app.map.on("layers-add-result", initEditor);
            var irrFieldsMSL = new ArcGISDynamicMapServiceLayer("http://gisweb1/arcgis/rest/services/Water/Irrigation_Mobile_one/MapServer");
            irrFieldsMSL.setDisableClientCaching(true);
            app.map.addLayer(irrFieldsMSL);
            var pumps = new FeatureLayer("http://gisweb/arcgis/rest/services/Water/Irrigation_Mobile_one/FeatureServer/0", {
                mode: FeatureLayer.MODE_ONDEMAND,
                outFields: ['*']
            pumps.name = "Pumps";
            var sideGate = new FeatureLayer("http://gisweb/arcgis/rest/services/Water/Irrigation_Mobile_one/FeatureServer/1", {
                outFields: ['*']
            var irrData = new FeatureLayer("http://gisweb/arcgis/rest/services/Water/Irrigation_Mobile_one/FeatureServer/2", {
                outFields: ['*']
            var canals = new FeatureLayer("http://gisweb/arcgis/rest/services/Water/Irrigation_Mobile_one/FeatureServer/5", {
                outFields: ['*']
            var idPipeLine = new FeatureLayer("http://gisweb/arcgis/rest/services/Water/Irrigation_Mobile_one/FeatureServer/4", {
                outFields: ['*']
            app.map.addLayers([pumps, sideGate, irrData,canals, idPipeLine]);
            var layerList = new LayerList({
                map: app.map,
                layers: [{ layer: pumps }, { layer: sideGate }, { layer: irrData }, { layer: canals }, { layer: idPipeLine }]
            },"layerList");
            layerList.startup();
            function initEditor(evt) {
                var templateLayers = arrayUtils.map(evt.layers, function (result) {
                    return result.layer;
                var templatePicker = new TemplatePicker({
                    featureLayers: templateLayers,
                    grouping: true,
                    rows: "auto",
                    columns: 3
                }, "templateDiv");
                templatePicker.startup();
                var layers = arrayUtils.map(evt.layers, function (result) {
                    return { featureLayer: result.layer };
                var settings = {
                    map: app.map,
                    templatePicker: templatePicker,
                    layerInfos: layers,
                    toolbarVisible: true,
                    createOptions: {
                        polylineDrawTools: [Editor.CREATE_TOOL_FREEHAND_POLYLINE],
                        polygonDrawTools: [Editor.CREATE_TOOL_FREEHAND_POLYGON,
                          Editor.CREATE_TOOL_CIRCLE,
                          Editor.CREATE_TOOL_TRIANGLE,
                          Editor.CREATE_TOOL_RECTANGLE
                    toolbarOptions: {
                        reshapeVisible: true
                var params = { settings: settings };
                var myEditor = new Editor(params, 'editorDiv');
                //define snapping options
                var symbol = new SimpleMarkerSymbol(
                  SimpleMarkerSymbol.STYLE_CROSS,
                  15,
                    SimpleLineSymbol.STYLE_SOLID,
                    new Color([255, 0, 0, 0.5]),
                  null
                app.map.enableSnapping({
                    snapPointSymbol: symbol,
                    tolerance: 20,
                    snapKey: keys.ALT
                myEditor.startup();
                var s = new Search({
                    enableButtonMode: false, //this enables the search widget to display as a single button
                    enableLabel: false,
                    enableInfoWindow: false,
                    showInfoWindowOnSelect: false,
                    map: app.map
                }, "search");
                s.on("search-results", function (result) {
                    console.log(result);
                    console.log(result.results[1][1]);
                    s.select(result.results[1][1]);
                    var selectQuery = new Query();
                    pumps.clearSelection();
                    var geom = result.results[1][1].feature.geometry;
                    console.log(geom);
                    var ex = new Extent(geom.x - 20, geom.y - 20, geom.x + 20, geom.y + 20, new SpatialReference(3857));
                    selectQuery.geometry = ex;
                    selectQuery.spatialRelationship = Query.SPATIAL_REL_CONTAINS;
                    pumps.selectFeatures(selectQuery, FeatureLayer.SELECTION_NEW, function (features) {
                        console.log(features);
                s.on("select-result", function (result) {
                var sources = s.get("sources");
                sources.push({
                    featureLayer: new FeatureLayer("http://gisweb/arcgis/rest/services/Water/Irrigation_Mobile_one/FeatureServer/0"),
                    searchFields: ["TIDNUMB"],
                    displayField: "CAT_2",
                    exactMatch: false,
                    outFields: ["CAT_2", "OBJECTID", "NUMB", "TYPE", "TIDNUMB", "Meter", "PUMP_NAME", "GPM", "EC", "Lateral"],
                    placeholder: "3708",
                    maxResults: 6,
                    maxSuggestions: 6,
                    enableSuggestions: true,
                    minCharacters: 0
                s.set("sources", sources);
                s.startup();
    </script>
</head>
<body class="claro">
    <div id="main" data-dojo-type="dijit/layout/BorderContainer" data-dojo-props="design:'headline'" style="width:100%;height:100%;">
        <div data-dojo-type="dijit/layout/ContentPane" id="header" data-dojo-props="region:'top'">
            Edit Irrigation Features
        </div>
        <div data-dojo-type="dijit/layout/ContentPane" data-dojo-props="region:'left'" style="width: 350px;overflow:hidden;">
            <div id="search"></div>
            <hr />
            <div style="height:300px; overflow-y:scroll">
                <div id="templateDiv"></div>
            </div>
            <div id="editorDiv"></div>
            <hr/>
            <div id="printButton"></div>
            <hr />
            <div id="drawingWrapper">
                Add some graphics:
                <div id="point" class="drawing">Point</div>
                <div id="freehandpolyline" class="drawing">Freehand Polyline</div>
                <div id="freehandpolygon" class="drawing">Freehand Polygon</div>
                <div id="circle" class="drawing">Circle</div>
            </div>
            <hr />
            <div id="layerToggle">
                Toggle Layers: <br />
                <div id="layerList"></div>
            </div>
        </div>
        <div data-dojo-type="dijit/layout/ContentPane" id="map" data-dojo-props="region:'center'"></div>
    </div>
</body>
</html>
  •                 s.on("search-results", function (result) {
  •                     console.log(result);
  •                     console.log(result.results[1][1]);
  •                     s.select(result.results[1][1]);
  •                     var selectQuery = new Query();
  •                     pumps.clearSelection();
  •                     var geom = result.results[1][1].feature.geometry;
  •                     console.log(geom);
  •                     var ex = new Extent(geom.x - 20, geom.y - 20, geom.x + 20, geom.y + 20, new SpatialReference(3857));
  •                     selectQuery.geometry = ex;
  •                     selectQuery.spatialRelationship = Query.SPATIAL_REL_CONTAINS;
  •                     pumps.selectFeatures(selectQuery, FeatureLayer.SELECTION_NEW, function (features) {
  •                         console.log(features);
  •                 s.on("select-result", function (result) {
I had the right idea with this code. I needed to just clear results of the search widgets and then do a selectFeatures call on the feature layer. It is working now.
In fact, I need to hook up the search widget result to Editor Selections so that the editor attribute inspector may access it.
RickeyFight
Ashish,
Can you post the code that you got to work?
AdamCommeford
Any examples of how you got this to work?
Would like to use this solution, thanks
