Have a uniquerenderer inside classbreakrenderer?
1865
11-30-2014 06:09 PM
EdwardSohn2
Need to use a classbreakrenderer, but for one of the class breaks of numbers 1-1, need to use uniquevaluerenderer for that class.
What is the best way to do this?
KenBuja
You can have a classbreakrenderer that only has a single value. Using the classbreakrenderer sample, set one state_fips to its own color. (This code will only show some states and counties since it's retrieving only the first 1000). Indiana (state_fips = 18) will be colored yellow.
<!DOCTYPE html>
<html>
  <head>
    <meta http-equiv="Content-Type" content="text/html; charset=utf-8">
    <!--The viewport meta tag is used to improve the presentation and behavior of the samples
      on iOS devices-->
    <meta name="viewport" content="initial-scale=1, maximum-scale=1,user-scalable=no">
    <title>Class Breaks Renderer</title>
    <link rel="stylesheet" href="http://js.arcgis.com/3.11/esri/css/esri.css">
    <style>
      html, body, #map{
        height: 100%;
        margin: 0;
        padding: 0;
    </style>
    <script src="http://js.arcgis.com/3.11/"></script>
    <script>
      var map;
      require([
        "esri/map", "esri/layers/FeatureLayer",
        "esri/InfoTemplate", "esri/symbols/SimpleFillSymbol",
        "esri/renderers/ClassBreaksRenderer",
        "esri/Color", "dojo/dom-style", "dojo/domReady!"
      ], function(
        Map, FeatureLayer,
        InfoTemplate, SimpleFillSymbol,
        ClassBreaksRenderer,
        Color, domStyle
        map = new Map("map", {
          basemap: "streets",
          center: [-88, 40],
          zoom: 7,
          slider: false
        var symbol = new SimpleFillSymbol();
        symbol.setColor(new Color([150, 150, 150, 0.5]));
        // Add five breaks to the renderer.
        // If you have ESRI's ArcMap available, this can be a good way to determine break values.
        // You can also copy the RGB values from the color schemes ArcMap applies, or use colors
        // from a site like www.colorbrewer.org
        // alternatively, ArcGIS Server's generate renderer task could be used
        var renderer = new ClassBreaksRenderer(symbol, "STATE_FIPS");
        renderer.addBreak(0, 5, new SimpleFillSymbol().setColor(new Color([56, 168, 0, 0.5])));
        renderer.addBreak(6, 17, new SimpleFillSymbol().setColor(new Color([139, 209, 0, 0.5])));
        renderer.addBreak(18, 18, new SimpleFillSymbol().setColor(new Color([255, 255, 0, 0.5])));
        renderer.addBreak(19, 20, new SimpleFillSymbol().setColor(new Color([255, 128, 0, 0.5])));
        renderer.addBreak(21, Infinity, new SimpleFillSymbol().setColor(new Color([255, 0, 0, 0.5])));
        var infoTemplate = new InfoTemplate("${NAME}", "${*}");
        var featureLayer = new FeatureLayer("http://sampleserver1.arcgisonline.com/ArcGIS/rest/services/Demographics/ESRI_Census_USA/MapServer/3", {
          mode: FeatureLayer.MODE_SNAPSHOT,
          outFields: ["*"],
          infoTemplate: infoTemplate
        //featureLayer.setDefinitionExpression("STATE_NAME = 'Kansas'");
        featureLayer.setRenderer(renderer);
        map.addLayer(featureLayer);
    </script>
  </head>
  <body>
    <div id="map"></div>
  </body>
</html>
EdwardSohn2
Actually need to have one of those classbreak renderer be not set to just a single symbol, but to another set of renderers- i.e. uniquerenderers with its own different sets of symbols.
Thanks.
