Has anyone implemented html5 browser history for a complex javascript Mapping application?
5285
01-28-2015 06:36 AM
MarkAndrews
I have a requirement to implement HTML 5 history tracking in my javascript application.  To Keep it simple I wanted to update the history state every time the user panned or zoomed on the map.  The problem is that each popstate event that gets triggered and I would reset the extent to the previous extent it also triggered the original event adding another item in the history state.
This is the code that sets the listener on the pan event...
var eventHandlers = [];
      var currentState = {};
      function setEventTriggers() {
           var e = map.on("pan-end", function (e) {
               var pt = e.extent.getCenter();
               var state = { action: "pan", x: pt.x, y: pt.y };
               if (currentState && (currentState.x == pt.x && pt.y == currentState.y)) {
                   console.debug("this is history");
               } else {
                   window.history.pushState(state, null, "CreateTract.aspx?x=" + pt.x + "&y=" + pt.y);
           eventHandlers.push(e);
this is the code that handles the pop state
      window.addEventListener("popstate", function (e) {
          event.stop(e);
          console.debug(e);
          prevStates = [];
          currentState = e.state;
          var url = document.location.href;
          //console.debug(url);
          var u = urlUtils.urlToObject(url);
          if (u.query) {
              if (u.query.x && u.query.y) {
                  var pt = new Point(u.query.x, u.query.y, map.spatialReference);
                  prevStates.push(state);
                  map.centerAt(pt);
          fsMap._processBasicRequest();
As you can see I set a Current state variable at the beginning of the pop state routine and then check to see whether the current state is the same as state which I would be putting into history...
As this is rather kluggy, I was hoping someone else had a better idea.
I also tried to disconnect the event triggers but that could get really complicated in my application which has alot of UI javascript classes that trigger there own events...
Mark Andrews
Durham, NC
JoshHevenor
Here's a little more on how I would do this (untested). I see now that you did pans only but the approach should work.
// Listen for the map extent to change
var extentListener = on.pausable(map, "extent-change", function(evt){
    // Write to history
    if (typeof history.pushState !== "undefined") {
// Listen for history stack to the be popped
window.on("popstate", function (evt) {
    // don't worry about writting new history until we're done
    extentListener.pause();
    // When the map has had its extent changed then resume writing history <<<<<<<<  A >>>>>>>>>>>
    on.once(map, "extent-change", function(evt){
        extentListener.resume();
    // Get the extent from evt.state or url
    var center = ...;
    var zoom = ...;
    // Set map location from history event...this triggers our one time listener at << A >>
    map.centerAndZoom(center, zoom);
JoshHevenor
There's a sample that's not quite related:
History API to track selected feature | ArcGIS API for JavaScript
The key may be to turn off your listener when you're setting your history.  Or check out
dojo/on view /dojo/on
JoshHevenor
    // Write to history
    var center = ...;
    var zoom = ...;
MarkAndrews
Josh,
thanks.  That was helpful.
