gsvc.buffer(params, showBuffer) issue
3846
09-18-2014 10:04 AM
ZhanGao
I try do a buffer around selected one polygon, but no buffer shows up. here is some code if anyone can find out why. this is a html page.
function doBuffer(evt) {
            var geometry = evt[0].geometry;
            map = theMap;
            symbol = new esri.symbol.SimpleFillSymbol(esri.symbol.SimpleFillSymbol.STYLE_SOLID,
            new esri.symbol.SimpleLineSymbol(esri.symbol.SimpleLineSymbol.STYLE_SOLID,
            new dojo.Color([255, 0, 0]), 2), new dojo.Color([255, 255, 0, 0.25]));
            var gsvc;
            gsvc = new esri.tasks.GeometryService("https://xxx.com/arcgis/rest/services/Utilities/Geometry/GeometryServer");
            switch (geometry.type) {
                case "point":
                    //var symbol = new SimpleMarkerSymbol(SimpleMarkerSymbol.STYLE_SQUARE, 10, new SimpleLineSymbol(SimpleLineSymbol.STYLE_SOLID, new Color([255, 0, 0]), 1), new Color([0, 255, 0, 0.25]));
                    break;
                case "polyline":
                    var symbol = new SimpleLineSymbol(SimpleLineSymbol.STYLE_DASH, new Color([255, 0, 0]), 1);
                    break;
                case "polygon":
                    //var symbol = new esri.symbols.SimpleFillSymbol(SimpleFillSymbol.STYLE_NONE, new SimpleLineSymbol(SimpleLineSymbol.STYLE_DASHDOT, new Color([255, 0, 0]), 2), new Color([255, 255, 0, 0.25]));
                    break;
            //var graphic = new esri.Graphic(geometry, symbol);
            //theMap.graphics.clear();
            //setup the buffer parameters
            var params = new esri.tasks.BufferParameters();
            params.distances = 500;
            params.bufferSpatialReference = new esri.SpatialReference({ wkid: 32612});
            params.outSpatialReference = theMap.spatialReference;
            params.unit =eval("esri.tasks.GeometryService.UNIT_FOOT");
            //polygon = new esri.geometry.Polygon(theMap.spatialReference);
            //polygon.addRing(theMap.graphics.graphics[0].geometry.rings);
//            params.geometries = [evt[0].geometry];
//           gsvc.buffer(params, showBuffer);
            if (geometry.type === "polygon") {
                //if geometry is a polygon then simplify polygon.  This will make the user drawn polygon topologically correct.
                gsvc.simplify([geometry], function (geometries) {
                    params.geometries = geometries;
            } else {
                params.geometries = [geometry];
        function showBuffer(bufferedGeometries) {
            dojo.forEach(bufferedGeometries, function(geometry) {
                theMap.graphics.add(graphic);
        //end for buffer.
