Grid not populating with findtask results
957
08-20-2013 09:51 AM
KennethRichards
I have a grid that I populate with the results of a selection on the map. I am trying to add the ability to perform text search using findtask. From what I can see the findtask executes just fine, I can log the results in console. Can anyone tell me why the grid is not updating when I run findtask?
findTask = new esri.tasks.FindTask(".../services/aasggeothermal/AZWellHeaders/MapServer");
 findParams = new esri.tasks.FindParameters();
 findParams.returnGeometry = true;
        findParams.layerIds = [0];
 findParams.searchFields = ["apino"];
 findParams.outSpatialReference = map.spatialReference;
function apiSearch(){
  findParams.searchText = dojo.byId("textSearch").value;
  findTask.execute(findParams, updateGrid);
I think my problem is in one of my loops.
function updateGrid(featureSet){
        console.log(featureSet);
  var data=[];
  var grid = dijit.byId('grid');
  dojo.forEach(featureSet, function (entry) {
   var logs = [],
    las = [],
    folders = [],
    relatedResource = entry.attributes.relatedresource === null ? "no value" : entry.attributes.relatedresource;
    //relatedResource = entry.attributes.relatedresource || "";
    //if (entry.attributes.relatedresource === null) {
   //if ( relatedResource.length >=4){
   var raw = relatedResource.split("|");
   raw.forEach(function (bit){
    var resource = bit.split(", ");
    if (resource[0] && resource[1]){
    var url = resource[1].trim();
    var name = resource[0].trim();
    var anchor = "<li><a href='" + url + "' target='_blank'>" + name + "</a></li>";
    if (url != null ){
    if ( url.indexOf(".tif", url.length -4) !==-1){
     logs.push(anchor);
    if ( url.indexOf(".pdf", url.length -4) !==-1){
     folders.push(anchor);
    if ( url.indexOf(".las", url.length -4) !==-1){
     las.push(anchor);
   data.push({
    objectid:entry.attributes.objectid,//0
    apino:entry.attributes.apino,//1
    otherid:entry.attributes.otherid,//2
    wellname:entry.attributes.wellname,//3
    county:entry.attributes.county,//4
    twp:entry.attributes.twp,//5
    rge:entry.attributes.rge,//6
    section_:entry.attributes.section_,//8
    drillertotaldepth:entry.attributes.drillertotaldepth,//9
    formationtd:entry.attributes.formationtd,//10
    wellname:entry.attributes.wellname,//11
    logField: '<ul>' + logs.join(" ") + '</ul>',
    lasField: '<ul>' + las.join(" ") + '</ul>',
    folderField: '<ul>' + folders.join(" ") + '</ul>'
  var dataForGrid= {
   items: data
  var store = new dojo.data.ItemFileReadStore({data:dataForGrid});
  grid.setStore(store);
JasonZou
The parameter returned from findTask is FindResult[]. Refer to https://developers.arcgis.com/en/javascript/jsapi/findresult-amd.html for details.
Change:
To:
function updateGrid(findResults){
    console.log(findResults);
    var featureSet = dojo.map(findResults, function(findResult) { return findResult.feature;});
I would also change
To:
relatedResource = entry.attributes.relatedresource || "no value";
As to the other portion that process the data, I would check one item that pushed to the data array, making sure it's correct.
