Graphics Not Being Included in PrintTask - NOT USING esri/dijit/Print
1283
09-24-2013 10:45 AM
RafaelFerraro
I have a Javascript application that is attempting to allow users to create exports (png,jpeg,pdf...etc) of the web maps they create inside the application.  I am NOT using the esri.dijit.Print, instead using the esri/tasks/PrintTask directly.
For whatever reason, I can't seem to include any graphics (in either a GraphicsLayer or FeatureLayer instance) in the export.  The Basemap and visible ArcGISDynamicMapServiceLayers are included exactly as expected.  As far as I can tell, there is no flag in either the PrintParameters or PrintTemplate classes that would block graphics.
When I look at the outgoing http request for PrintTask.execute(), the graphics are DEFINITELY not included.  Is there something I am missing, any way to force graphics to be included on PrintTask.execute()?
VinayBansal
Print task exports graphics that are displayed on map in Print.
Please share your code so that we can have a look. Also, make sure you have added the print task url in the proxy.config.
RafaelFerraro
Thanks for your response.  Here is the crux of the code I am using for my print task - no graphics layers ever make into exported map.  As for proxy.config (ASP.NET backend), I have the mustMatch set to false, so I dont believe I need to add print task url.
 var printParams = new esri.tasks.PrintParameters();
                printParams.map = App.map;
                var template = new esri.tasks.PrintTemplate();
                template.format = "pdf";
                template.layout = $('#selLayout').val();
                template.preserveScale = true;
                template.layoutOptions = {
                    titleText: $('#inputMapTitle').val(),
                    authorText: $('#inputMapAuthor').val(),
                    scalebarUnit: $('#selScalebarUnit').val()
                printParams.template = template;
                var deferred = Mod.controller.printTask.execute(printParams);
