graphics Multiple clicks will cause errors
2443
10-31-2022 01:28 AM
MrLei
Uncaught TypeError: Object.defineProperty called on non-object
JayakumarPD
Is it possible to share the code.  It will be easy to understand
MrLei
Hi  thanks
code
showPopupInfo(data){
      let graphics = this.graphicsLayer.graphics.items
      let graphic = graphics.find(item => item.attributes.id == data.id)
      if(graphic != undefined){
        // .centroid
        this.mapView.popup.open({
               features: [graphic]
      }else{
        this.ssmap.mapView.popup.close()
getCentrePoint(geometry) {
    if (geometry.type === "polygon") {
      return geometry.centroid;
    if (geometry.type === "polyline") {
      return geometry.extent.center;
    return geometry;
The first display is normal
when change show popup or  more click others marker     this error can occur,
what's why
JayakumarPD
I am unable to create the exact your use case, but tried with point creation.
Popup is coming with exact latitude and longitude for each point I have clicked.
Screen shot enclosed.
<html>
  <head>
    <meta charset="utf-8" />
    <meta
      name="viewport"
      content="initial-scale=1,maximum-scale=1,user-scalable=no"
    <title>Draw polyline | Sample | ArcGIS API for JavaScript 4.24</title>
    <link
      rel="stylesheet"
      href="https://js.arcgis.com/4.24/esri/themes/light/main.css"
    <script src="https://js.arcgis.com/4.24/"></script>
    <style>
      html,
      body,
      #viewDiv {
        height: 100%;
        width: 100%;
        margin: 0;
        padding: 0;
    </style>
    <script>
      require([
        "esri/Map",
        "esri/views/MapView",
        "esri/views/draw/Draw",
        "esri/Graphic",
        "esri/views/draw/PointDrawAction",
        "esri/widgets/Popup",
      ], (Map, MapView, Draw, Graphic, PointDrawAction, Popup) => {
        const map = new Map({
          basemap: "gray-vector",
        const view = new MapView({
          container: "viewDiv",
          map: map,
          zoom: 15,
          center: [75, 14],
        view.ui.add("point-button", "top-left");
        const draw = new Draw({
          view: view,
        document.getElementById("point-button").onclick = () => {
          const action = draw.create("point");
          view.focus();
          action.on(["draw-complete"], updateVertices);
        function updateVertices(event) {
          if (event.coordinates.length > 1) {
            const result = createGraphic(event);
        function createGraphic(event) {
          let point = {
            type: "point",
            x: event.coordinates[0],
            y: event.coordinates[1],
            spatialReference: view.spatialReference,
          let graphic = new Graphic({
            geometry: point,
            symbol: {
              type: "simple-marker",
              style: "circle",
              color: "red",
              outline: {
                color: [255, 255, 0],
                width: 3,
          view.graphics.add(graphic);
          showPopup(graphic);
        function showPopup(graphic) {
          console.log(
            graphic.geometry.latitude + " - " + graphic.geometry.longitude
          view.popup.open({
            content: `<b>latitude: ${graphic.geometry.latitude} <br/> latitude: ${graphic.geometry.longitude}<b>`,
    </script>
  </head>
  <body>
    <div id="viewDiv">
      <div
        id="point-button"
        class="esri-widget esri-widget--button esri-interactive"
        title="Draw Point"
        <span class="esri-icon-map-pin"></span>
      </div>
    </div>
  </body>
</html>
MrLei
ok  thank you !
sometimes this happens,I don't know if it is caused by different versions ,I also use new version
