Graphics Layer Click Event Not Firing When Shape Is In Edit Mode
2951
09-06-2013 08:23 AM
DK5
I am having an issue with graphic layer events in version 3.5.
I have a mouse-over event where I am set the shape into Move edit mode.  I also have a click event that I want to capture that will set the shape into Move, Rotate, Scale modes, as well as show the infotemplate.
The click event on the graphics layer is never fired when I set the edit mode to Move in the mouse-over event, but does fire when I don't set the edit mode.  Is this because when the shape is in edit mode, no other graphics layer events will be fired?
Any suggestions?
DK5
Issue solved.
Looks like it works when doing map.graphics.on("mouse-over", ..... and map.graphics.on("click"...
The code originally was doing dojo.connect(map.graphics, "onClick".... and "onMouseOver"....
