Graphics appearing above or below the basemap
1874
12-30-2020 06:40 AM
rogenjh
Running into a weird issue I was was wondering about. Is there any way to adjust whether the graphics of a feature layer appear above or below the basemap? We're looking to implement a gray-vector map, but currently city names are appearing above the symbols. I noticed that when I change the style of basemap, this issue disappears.
Is this something I can adjust?
JohnGrayson
Esri Alum
Some basemaps are designed with the labels as a separate reference layer, meaning they will appear above your operational layers.  One option for this use-case is to not make them a reference layer, which you can do in your specific Web Map in both the Map Viewer and Map Viewer Beta when authoring your map.
JohnGrayson
Esri Alum
rogenjh
Thanks so much! Super helpful. I was using the default basemap, but I'm going to go back in next week and update to the Webmap like you say!
