Graphic Layer
512
03-15-2011 05:33 PM
AmorndechUdomdilokphop
I'm Add Layer Graphic Layer on the MAP, but the graphic on the layer move when i pan around. I want Graphic Layer move match coordinate. i editing form code not work. can u help me
For example:
you can't just have
var NewGraphics
NewGraphics = new esri.layers.GraphicsLayer({});
map.addLayer(NewGraphics);
Instead you have to have
dojo.connect(map, "onLoad", function() {
HemingZhu
For example:
you can't just have
var NewGraphics
set map's property displayGraphicsOnPan to false. so that graphic wouldn't display until the panning is over. It is less confusing and improve performance too.
