GP results as a popup with formatted text / images
1524
09-24-2014 02:19 PM
ErikMartin
I am trying to take the text results of a geoprocessing service and display them in a popup in a javascript map.  I am able to do this successfully using a Dojo Dialog, but I'm wondering if there are options with more formatting control of the text -- more akin to an Esri Popup with formatted text, links, images, etc. -- but associated with a submitJob result, not an Identify/Query event.  Is the Dojo Dialog my best bet?  Possible with an Esri Popup?  JQuery?  Other options?
Thanks
Erik
ErikMartin
The Dojo Dialog has worked well by building up the HTML string in javascript -- including HTML tags as part of the string -- then passing it to the Dialog as the content variable.
ErikMartin
