GoTo zoom to specific LOD not working JS API 4.4
2680
08-04-2017 10:19 AM
by Anonymous User
Not applicable
Hi all,
I am trying to zoom to a parcel so I am using the "goTo" function. It works great. However when I input my target (AOI) and the zoom level (LOD). It does not work. Any idea why?
code to zoom:
function zoomparcel(result){
              var AOI = result.features;
              view.goTo({target: AOI, zoom:15});}
 code:
<!DOCTYPE html>
<html>
<head>
  <meta charset="utf-8">
  <meta name="viewport" content="initial-scale=1, maximum-scale=1,user-scalable=no">
  <title>Print widget - 4.4</title>
  <!-- Latest compiled and minified CSS -->
  <link href="https://maxcdn.bootstrapcdn.com/font-awesome/4.7.0/css/font-awesome.min.css" rel="stylesheet" integrity="sha384-wvfXpqpZZVQGK6TAh5PVlGOfQNHSoD2xbE+QkPxCAFlNEevoEH3Sl0sibVcOQVnN" crossorigin="anonymous">
  <link rel="stylesheet" href="https://maxcdn.bootstrapcdn.com/bootstrap/3.3.7/css/bootstrap.min.css" integrity="sha384-BVYiiSIFeK1dGmJRAkycuHAHRg32OmUcww7on3RYdg4Va+PmSTsz/K68vbdEjh4u" crossorigin="anonymous">
  <link rel="stylesheet" href="https://js.arcgis.com/4.4/esri/css/main.css">
  <style>
    html,
    body,
    #viewDiv {
      padding: 0;
      margin: 0;
      height: 100%;
      width: 100%;
      overflow: hidden;
    #search {
        width: 400px;
        z-index: 1;
        position: absolute;
        left: 80px;
        top: 15px;
  </style>
  <script src="http://code.jquery.com/jquery-3.2.1.min.js"integrity="sha256-hwg4gsxgFZhOsEEamdOYGBf13FyQuiTwlAQgxVSNgt4=" crossorigin="anonymous"></script>
  <!-- Latest compiled and minified JavaScript -->
  <script src="https://maxcdn.bootstrapcdn.com/bootstrap/3.3.7/js/bootstrap.min.js" integrity="sha384-Tc5IQib027qvyjSMfHjOMaLkfuWVxZxUPnCJA7l2mCWNIpG9mGCD8wGNIcPD7Txa" crossorigin="anonymous"></script>
  <script src="https://js.arcgis.com/4.4/"></script>
  <script>
    require([
        "esri/Map",
        "esri/views/MapView",
        "esri/widgets/Print",
        "esri/tasks/QueryTask", "esri/tasks/support/Query",
        "esri/layers/FeatureLayer",
        "esri/layers/GraphicsLayer",
        "esri/geometry/geometryEngine",
        "esri/Graphic",
        "esri/widgets/BasemapGallery",
        "esri/symbols/SimpleFillSymbol",
        "esri/symbols/SimpleMarkerSymbol",
        "esri/layers/MapImageLayer",
        "dojo/on",
        "dojo/dom",
        "dojo/dom-construct",
        "dojo/domReady!"
      function(
        Map, MapView, Print, QueryTask, Query, FeatureLayer, GraphicsLayer,
        geometryEngine,
        Graphic,
        BasemapGallery,
        SimpleFillSymbol,
        SimpleMarkerSymbol,
        MapImageLayer,
        on, dom, domConstruct
        var map = new Map({basemap: 'topo'});
        //Layers to add
        var lakes = new FeatureLayer({
            url: "http://gem.edcgov.us/arcgis/rest/services/water/water2SQL_WAB/MapServer/1"
        var rivers = new FeatureLayer({
            url: "http://gem.edcgov.us/arcgis/rest/services/water/water2SQL_WAB/MapServer/0"
        var roads = new MapImageLayer({
            url: "http://gem.edcgov.us/arcgis/rest/services/transpt/Roads/MapServer"
        var Parcels = new MapImageLayer({
    url: "http://gem.edcgov.us/arcgis/rest/services/Sheriff/Parcels/MapServer"
  var image = new MapImageLayer({
    url: "http://gem.edcgov.us/arcgis/rest/services/surface/Aerials_2011_mercator_WAB/MapServer"
  var contours = new FeatureLayer({
    url: "http://gem.edcgov.us/arcgis/rest/services/mixed/surface2SQL_WAB/MapServer/16"
        $("#execute").click(function (){
            var value = $( "#searchtext" ).val();
            $(".esri-print__input-text").val("APN " + value).trigger("input");
            console.log(value);
            var queryparcelTask  = new QueryTask({url: "http://gem.edcgov.us/arcgis/rest/services/Sheriff/Parcels/MapServer/0"});
            var query = new Query();
            query.returnGeometry = true;
            query.outFields = ["*"];
            query.where = "PRCL_ID = '" +   value + "'";
           queryparcelTask.execute(query).then(zoomparcel)
        map.addMany([Parcels, lakes, rivers ]);
        var opts = {
          duration: 5000  // Duration of animation will be 5 seconds
        var view = new MapView({
          container: "viewDiv",
          map: map,
          extent: { // autocasts as new Extent()
            "xmin": -121.11087086999999, "ymin": 38.517479534000074, "xmax": -119.95226375799996, "ymax": 39.068026806000034,
            "spatialReference": { "wkid": 4326 }
        view.then(function() {
          var print = new Print({
            view: view,
            // specify your own print service
            printServiceUrl: "http://gem.edcgov.us/arcgis/rest/services/Alex_test/ExportWebMapAlex6/GPServer/Export%20Web%20Map"
          // Add widget to the top right corner of the view
          view.ui.add(print, "top-right");
  </script>
</head>
<body class="calcite">
 <div class="row">
    <div class="col-lg-6">
    <div class="input-group" id="search">
      <input type="text" id="searchtext" class="form-control" placeholder="Enter APN">
      <span class="input-group-btn">
        <button class="btn btn-secondary" type="button" id="execute"><i class="fa fa-search" aria-hidden="true"></i></button>
      </span>
    </div>
  </div>
</div>
  <div id="viewDiv"></div>
</body>
</html>
Tags (1)
ReneRubalcava
Esri Frequent Contributor
Your map is in spatial reference 4326, but your query results are in 2226.
You need to set the outSpatialReference of the Query to match the map.
query.outSpatialReference = { wkid: 4326 }‍‍
I think that will work, I don't know a parcel number to properly test against.
ReneRubalcava
