goTo function zooming only to one geometry
3414
05-02-2022 04:18 AM
eyalj
Hey,
Im trying to do the goto function for serval geometry but it seems it zooming only to the last geometry in the array,
not really sure why and how to handle it
that's the Array of Geometry im passing, in not getting any errors
Tags (3)
KenBuja
MVP Esteemed Contributor
What does your code look like? This modified sample works properly
<html>
  <head>
    <meta charset="utf-8" />
    <meta
      name="viewport"
      content="initial-scale=1,maximum-scale=1,user-scalable=no"
    <title>Intro to graphics | Sample | ArcGIS API for JavaScript 4.23</title>
    <link
      rel="stylesheet"
      href="https://js.arcgis.com/4.23/esri/themes/light/main.css"
    <script src="https://js.arcgis.com/4.23/"></script>
    <style>
      html,
      body,
      #viewDiv {
        padding: 0;
        margin: 0;
        height: 100%;
        width: 100%;
    </style>
    <script>
      require(["esri/Map", "esri/views/MapView", "esri/Graphic"], (
        Map,
        MapView,
        Graphic
        const map = new Map({
          basemap: "hybrid"
        const view = new MapView({
          center: [-80, 35],
          container: "viewDiv",
          map: map,
          zoom: 3
         * Create a polygon graphic
        // Create a polygon geometry
        const polygon = {
          type: "polygon", // autocasts as new Polygon()
          rings: [
            [-64.78, 32.3],
            [-66.07, 18.45],
            [-80.21, 25.78],
            [-64.78, 32.3]
        const polygon1 = {
          rings: [
            [-84.78, 32.3],
            [-86.07, 18.45],
            [-90.21, 25.78],
            [-84.78, 32.3]
        // Create a symbol for rendering the graphic
        const fillSymbol = {
          type: "simple-fill", // autocasts as new SimpleFillSymbol()
          color: [227, 139, 79, 0.8],
          outline: {
            // autocasts as new SimpleLineSymbol()
            color: [255, 255, 255],
            width: 1
        // Add the geometry and symbol to a new graphic
        const polygonGraphic = new Graphic({
          geometry: polygon,
          symbol: fillSymbol
        const polygonGraphic1 = new Graphic({
          geometry: polygon1,
          symbol: fillSymbol
        // Add the graphics to the view's graphics layer
        view.graphics.addMany([polygonGraphic, polygonGraphic1]);
        view.graphics.on("after-add",()=>{
          view.goTo({
            target: [polygonGraphic.geometry, polygonGraphic1.geometry]
    </script>
  </head>
  <body>
    <div id="viewDiv"></div>
  </body>
</html>
eyalj
view.goTo(geometryArr);
GeometryArry is the array in the first pictrue
And that's the view
 notice that it works it just zooming to one of the geometry in the array instead of all of them
DimaY
No, you are not very right. Only this simple example works and that's it. I have exactly the same problem, I already opened a topic on this forum. So no one answered. There is a bug, some kind of malfunction, and this must be recognized. When a lot of graphs are added, the view.goTu gets lost where to go and shows everything incorrectly, and this is putting it mildly.
ReneRubalcava
Esri Frequent Contributor
Can you provide a codepen showing the issue?
https://codepen.io/
No way to tell without seeing it in action. It could be a bad geometry, spatial reference mismatch, or something else.
