Google Street View Not Working
7634
08-26-2016 08:36 AM
ShaningYu
Honored Contributor
Several months ago, the Google Street View worked well in my application in html format.
Then, I created an aspx page and loaded all of the HTML code into it.  When I click the Google Street Map again, I received warning message: "Oops! Something went wrong.  This page did not load Google Maps correctly.  See the JavaScript code for technical details."  Through Chrome F12, the error message is Google Maps API error:
MissingKeyMapError.  Then, I checked  https://developers.google.com/maps/documentation/javascript/error-messages#missing-key-map-error
and followed the instruction (https://developers.google.com/maps/documentation/javascript/get-api-key ) and get the key.  I copied pasted the code:
<script async defer src="https://maps.googleapis.com/maps/api/js?key=myKeyHere&callback=initMap"
  type="text/javascript">
But I still get runtime error. Did I do something wrong?   Thanks if you can help..
Tags (1)
ShaningYu
Honored Contributor
Re-worked on the key setting and got the problem solved.  Thanks for your review.
ShaningYu
Honored Contributor
I have to re-activate my thread again since it works on one of my deployed IIS service but not on another one.  In both of them the domains are the same.  Should I do some settings on the IIS?  Thanks.
XanderBakker
Esri Esteemed Contributor
Please have a look at an important note placed at: Google Street View Widget 2.1 - 08/29/16 .  As it appears, the Widget is not conform to the Google Maps API Terms of Service!
RobertScheitlin__GISP
Shaning,
   You need to stop using Google StreetView in your application. There is no way to be compliant with Google TOS unlees you are only using the Google Maps API and a google basemap. You can NOT display a StreetView image with a map (i.e. esri map) other than a Google map.
Read up on Google TOS 10.4.d and 10.4.e
I recently took down my Google StreetView widget do to this TOS Violation.
