Google base Map not visible
2414
04-17-2016 02:46 AM
NadirHussain
Dear all i am using google as a base ma.i find all of examples but all are in legacy modules.I am using amd dojo.how to add these it should work for me.
    <script type="text/javascript">
        var djConfig = {
            parseOnLoad: true,
            baseUrl: './',
            modulePaths: {
                // if use local copy, make sure the path reference is relative to 'baseUrl', e.g.:
                //'agsjs': '../build/agsjs'
                // use absolute path for online version. Note sometimes googlecode.com can be slow.
                'agsjs': 'http://gmaps-utility-gis.googlecode.com/svn/tags/agsjs/1.07/build/agsjs'
       </script>
require([
          "esri/dijit/BasemapGallery", "dojo/_base/json",  "dijit/layout/ContentPane", "dijit/TitlePane", "dojo/domReady!"
    ], function ( BasemapGallery, dojoJson,CP,TP ) {
function createBasemapGallery() {
                //Manually create a list of basemaps to display
                basemaps.push(new esri.dijit.Basemap({
                    layers: [new esri.dijit.BasemapLayer({
                        type: 'GoogleMapsRoad'
                    title: "Google Road",
                    thumbnailUrl: "images/icons/GoogleRoads.jpg"
                        type: 'GoogleMapsSatellite'
                    title: "Google Satellite",
                    thumbnailUrl: "images/icons/GoogleSatelite.jpg"
                        type: 'GoogleMapsHybrid'
                    title: "Google Hybrid",
                    thumbnailUrl: "images/icons/GoogleHybrid.jpg"
var basemapGallery = new BasemapGallery({ showArcGISBasemaps: true, basemaps: basemaps, bingMapsKey: "Au4pcSZ", google: {
                                apiOptions:{ // google api options.
                                    v: 3.6,
                            }, map: map }, "basemapGallery");
some code is not there.please help.Beacuse on my click event all other base map change even bing map com on click basemap gallery.only google map not come.please help.
