GIF is not animation in ArcGIS JS API 5
1068
03-02-2026 02:54 PM
DECCA_Jimmy
Hello Support:
Since I upgraded JS API from 4 to 5.   I found GIF file is not animation in PicutreMarkerSymbol.  Can you check it, then fix that in next version.
Thanks
AnneFitz
Hi @DECCA_Jimmy - thanks for reporting this, we'll look into it.
AnneFitz
This issue was fixed in patch 5.0.9. See the patch fixes in the release notes (5.0.9 should be up by the end of the day!) Let us know if you're still running into issues.
