Getting the polygon Id.
1094
12-18-2012 11:25 PM
PrasannaRaghavendar
I have a base map and a layer on it which has polygons. How should I get the polygon Id of the polygon that is clicked?
Prasanna
RahulMetangale1
Hi Prasanna,
you have to do a spatial query, following sample would help:
http://help.arcgis.com/en/webapi/javascript/arcgis/help/jssamples_start.htm#jssamples/query_clickinf...
PrasannaRaghavendar
I have found that I have a webservice method with which I can get the Polygon Id from. But I would need the geometry of the polygon in order to call that method.
How will I get the geometry of the polygon?
Prasanna
