Getting feature layer attributes as object without Query using query class
6271
9
02-13-2017 06:05 AM
by Anonymous User
Not applicable
I know I can get feature layer attributes using Query class, but is there another way to get all attributes in a feature layer?
RobertScheitlin__GISP
Ah. that make sense now. Here is a 4.2 version of the sample:
<!DOCTYPE html>
<html>
<head>
  <meta http-equiv="Content-Type" content="text/html; charset=utf-8">
  <meta name="viewport" content="initial-scale=1, maximum-scale=1,user-scalable=no" />
  <title>Request Test</title>
  <link rel="stylesheet" href="http://js.arcgis.com/4.2/esri/css/main.css">
  <link rel="stylesheet" type="text/css" href="http://js.arcgis.com/4.2/dijit/themes/claro/claro.css">
  <style>
    html,
    body,
    #viewDiv {
      height: 100%;
      width: 100%;
      margin: 0;
      padding: 0;
    body {
      background-color: #FFF;
      overflow: hidden;
      font-family: "Trebuchet MS";
    #header {
      height: 3%;
      overflow: auto;
  </style>
  <script>
    var dojoConfig = {
      parseOnLoad: true
  </script>
  <script src="http://js.arcgis.com/4.2/"></script>
  <script>
    var map;
    require([
      "esri/Map",
      "esri/views/MapView",
      "dojo/_base/lang",
      "esri/request",
      "dijit/layout/BorderContainer",
      "dijit/layout/ContentPane",
      "dojo/domReady!"
    ], function(
      Map, MapView, lang, esriRequest
      map = new Map({
        basemap: "topo"
      var view = new MapView({
        container: "viewDiv",
        map: map,
        zoom: 4,
        center: [15, 65]
      var url = "http://sampleserver6.arcgisonline.com/arcgis/rest/services/NapervilleShelters/FeatureServer/0/query?...";
      esriRequest(url,{
          responseType:'json',
          callbackParamName:'callback',
          timeout:15000
        }).then(lang.hitch(this,function(resp){
          console.info(resp.data);
          alert("Data returned");
        }),lang.hitch(this,function(error){
          alert("Data failed");
  </script>
</head>
<body class="claro">
  <div id="viewDiv" data-dojo-type="dijit/layout/BorderContainer" data-dojo-props="design:'headline', gutters:false" style="padding:0px;margin:0px;">
    <div id="map" data-dojo-type="dijit/layout/ContentPane" data-dojo-props="region:'left'" style="width:100%;height:100%;border:none;padding:0px;margin:0px;"></div>
  </div>
</body>
</html>
SarojThapa1
Makiko,
Do you want to display attributes of a feature layer as a Popup Window? If yes, then check this sample out.
ArcGIS API for JavaScript Sandbox
Makiko,
   Hmm.. any particular reason why? The QueryTask is the main JS API route to get attribute values. The other way would be to just use a esriRequest directly to the map service to get the attribute values for a know ObjectID.
by Anonymous User
Not applicable
Hi Saroj and Robert,
Thank you so much for your quick response.  There is no special reason not using QueryTask class.  Since I need all attributes in a feature layer in JSON format so I thought it might have something other than QueryTask class that gives me direct access to JSON formatted attributes.
esriRequest seems to be the answer for my question, but does it work on a feature service layer?  I looked at the example and replaced url to feature service layer, but it didn't return anything.  Does esriRequest only work for GeoJson layer?
var url = "https://services.arcgis.com/.../arcgis/rest/services/.../FeatureServer/0"
esriRequest(url, {
responseType: "json"
}).then(function(response){
// The requested data
console.log(response);
var dataJson = response.data;
console.log(dataJson)
Thank you,
Makiko
Makiko,
   You absolutely can use an esriRequest on things other then GeoJSON.
esriRequest({
  url: "https://sampleserver6.arcgisonline.com/arcgis/rest/services/NapervilleShelters/FeatureServer/0/query...",
  handleAs: "json",
  timeout: 10000
  console.info(response);
by Anonymous User
Not applicable
Hi Robert,
I tested your code, but it gave me an error.  This is not a big deal so I fixed it and tried it again.  But it still doesn't give me any response.  Though, the example code that uses GeoJson works fine. I wonder what is the problem with the feature service layer.
Makiko,
   I am not sure whats going wrong in your code then. Here is a full example of using esriRequest:
<!DOCTYPE html>
<html>
<head>
  <link rel="stylesheet" type="text/css" href="http://js.arcgis.com/3.18/dijit/themes/claro/claro.css">
  <link rel="stylesheet" type="text/css" href="http://js.arcgis.com/3.18/esri/css/esri.css">
  <style>
    html,
    body,
    #mainWindow {
      height: 100%;
      width: 100%;
      margin: 0;
      padding: 0;
    body {
      overflow: hidden;
    #header {
      height: 3%;
      overflow: auto;
  </style>
  <script>
    var dojoConfig = {
      parseOnLoad: true
  </script>
  <script src="http://js.arcgis.com/3.18/"></script>
  <script>
    var map;
    require([
      "esri/map",
      "dojo/_base/lang",
      "esri/request",
      "dojo/domReady!"
    ], function(
      Map, lang, esriRequest
      map = new Map("map", {
        basemap: "topo",
        center: [-120.1883, 37.0868],
        zoom: 6
      esriRequest({
          url:"http://sampleserver1.arcgisonline.com/ArcGIS/rest/services/Louisville/LOJIC_LandRecords_Louisville/M...",
          content:{
            f:'json'
          handleAs:'json',
          timeout:15000
          console.info(resp);
          if(resp.layers){
            resp.layers.forEach(function(layerInfo){
               //Do something
  </script>
</head>
  <div id="mainWindow" data-dojo-type="dijit/layout/BorderContainer" data-dojo-props="design:'headline', gutters:false" style="padding:0px;margin:0px;">
  </div>
</body>
</html>
by Anonymous User
Not applicable
Hi Robert,
I am using JavaScript API 4.2.
<!DOCTYPE html>
<html>
<head>
  <style>
    html,
    body,
    #viewDiv {
      height: 100%;
      width: 100%;
      margin: 0;
      padding: 0;
    body {
      overflow: hidden;
    #header {
      height: 3%;
      overflow: auto;
  </style>
  <script>
    var dojoConfig = {
      parseOnLoad: true
  </script>
  <script>
    var map;
    require([
      "esri/Map",
      "dojo/_base/lang",
      "esri/request",
      "dojo/domReady!"
    ], function(
      map = new Map({
        basemap: "topo"
        map: map,
        zoom: 4,
        center: [15, 65]
      esriRequest(url,{
          timeout:15000
  </script>
</head>
  </div>
</body>
</html>
by Anonymous User
Not applicable
Hi Robert,
Wonderful!! It works perfectly.  Thank you so much!
