Getting error while implementing Turf with Arcgis
2599
04-21-2021 11:58 AM
SahilBansal
While implementing the Turf with the Arcgis, below error is coming:
Argument of type '{ type: string; properties: { stroke: string; }; features: { type: string; properties: { color: string; }; geometry: { type: string; coordinates: number[][]; }; }[]; }' is not assignable to parameter of type 'Position[]'.
PFB the code snippet:
 const getPoint = () => {
      var line = turf.lineString({
        type: 'FeatureCollection',
        features: [
            type: 'Feature',
            properties: {
              color: 'orange'
            geometry: {
              type: 'Polygon',
              coordinates: [
        [-77.03166938.878605],
        [-77.02960938.881946],
        [-77.02033938.884084],
        [-77.02566138.885821],
        [-77.02188438.889563],
        [-77.01982438.892368],
      const pt = turf.point([this.latthis.lon]);
      console.log('Inside turf'this.lat);
      const snapped = turf.nearestPointOnLine(linept, {units: 'miles'});
ReneRubalcava
Esri Frequent Contributor
Turf isn't an Esri product. You can get support on the github page for turf https://github.com/Turfjs/turf/
SahilBansal
I checked this link as well. I just wanna used the properties to show the nearby points on the map for a given route. So that is why i am using TUrf.
Is there any way to do that in Arcgis using Turf.
ReneRubalcava
You'll need to covert the GeoJSON result to an ArcGIS geometry.
https://developers.arcgis.com/javascript/latest/api-reference/esri-geometry-Point.html
Point takes a latitude and longitude you can use. I have no samples for this.
