Getting error when using buildLayerList function.
3048
03-31-2015 08:30 AM
ManjariGoyal
I am trying to create layer list but it doesn't show when running in the JavaScript. I am not sure what is missing here. Below is the code I am using.
var FiberInfoTemplate = new InfoTemplate();
                FiberInfoTemplate.setTitle("<b>Fiber Provider</b>");
                var Fiber1InfoTemplate = new InfoTemplate();
                Fiber1InfoTemplate.setTitle("<b>Fiber Provider</b>");
                var Fiber2InfoTemplate = new InfoTemplate();
                Fiber2InfoTemplate.setTitle("<b>Fiber Provider</b>");
                FiberInfoTemplate.setContent("PROVIDER: ${PROVIDER}<br/>");
                Fiber1InfoTemplate.setContent("PROVIDER: ${PROVIDER}<br/>");
                Fiber2InfoTemplate.setContent("PROVIDER: ${PROVIDER}<br/>");
                var FiberLayerURL = "https://corp.abc.com/network/rest/services/AMTools/Fiber/MapServer";
                var FiberLayerOptions = {
                    "id": "demographicsLayer",
                        "opacity": 0.75,
                        "showAttribution": false
               var FiberLayer = new ArcGISDynamicMapServiceLayer(FiberLayerURL, FiberLayerOptions);
                FiberLayer.setInfoTemplates({
                0: { infoTemplate: FiberInfoTemplate },
                1: { infoTemplate: Fiber1InfoTemplate },
                2: {infoTemplate: Fiber2InfoTemplate}
                //1 and 5 are the layer id number.
                //FiberLayer.setVisibleLayers([0, 1, 2]);
                //map.addLayer(FiberLayer);
                FiberLayer.on("load", buildLayerList);
                function buildLayerList() {
                    var items = arrayUtils.map(Fiberlayer.layerInfos, function(info, index) {
                    if (info.defaultVisibility) {
                        visible.push(info.id);
                    return "<input type='checkbox' class='list_item'" + (info.defaultVisibility ? "checked=checked" : "") + "' id='" + info.id + "'' /><label for='" + info.id + "'>" + info.name + "</label>";
                    var ll = dom.byId("layer_list");
                    ll.innerHTML = items.join(' ');
                    Fiberlayer.setVisibleLayers(visible);
                    on(ll, "click", updateLayerVisibility);
                function updateLayerVisibility() {
                    var inputs = query(".list_item");
                    var input;
                    visible = [];
                    arrayUtils.forEach(inputs, function(input) {
                    if (input.checked) {
                    visible.push(input.id);
                    //if there aren't any layers visible set the array to be -1
                    if (visible.length === 0) {
                    visible.push(-1);
