getting a TypeError
7116
14
10-18-2014 04:50 AM
joepublic
I am still new to esri's js-api.  I am getting the error below at line 149 (queryTask.execute(cntryq);) in the attached file.
I have no idea how to resolve this error
TypeError {stack: "TypeError: undefined is not a function↵ at coun…ndler (http://js.arcgis.com/3.10/init.js:490:212)", message: "undefined is not a function"}
  1. message: "undefined is not a function"
  2. stack: "TypeError: undefined is not a function↵ at countries (http://tobagoborn.com/esri/examples/p1p2c.html:149:15)↵ at cntrycds (http://tobagoborn.com/esri/examples/p1p2c.html:163:5)↵ at http://tobagoborn.com/esri/examples/p1p2c.html:179:7↵ at S._resolve (http://js.arcgis.com/3.10/js/esri/layers/FeatureLayer.js:64:294)↵ at k (http://js.arcgis.com/3.10/js/esri/layers/FeatureLayer.js:65:355)↵ at c (http://js.arcgis.com/3.10/init.js:74:221)↵ at d (http://js.arcgis.com/3.10/init.js:74:10)↵ at resolve.callback (http://js.arcgis.com/3.10/init.js:75:350)↵ at Object.n._resDfd (http://js.arcgis.com/3.10/init.js:758:31)↵ at e._successHandler (http://js.arcgis.com/3.10/init.js:490:212)"
Tags (1)
DanPatterson_Retired
can you redirect your post to an appropriate Place to facilitate answering
joepublic
Where is the appropriate place??
See the big Places link to the left of your avatar, click on it, then you can select a Space and post/move your question there.  I am guessing you have some sort of java question but it could go in several spots, ie what are you using/developing. you will get better response if you use places/spaces and tags to direct your questions otherwise they end up in the void
joepublic
I am using ESRI's javascript API so I think I need someone from ESRI to look at it
Correct??
If someone from Esri has to look at it, then you had better send a request to tech support.  If you want help, this is a user site and Esri staff do mingle in our midst as well.
MatthewLewis
Ok... firstly this code needs a tidy up! Split out your code and use standards, otherwise know one will want to read it and help you.
I've played around and improved the structure. I don't seem to be getting any TypeErrors
joepublic
Mathew,
Thanks for the quick code review and the assist.
I agree my code is rather crude and inefficient.
My original plan was to use esri-leaflet api but it could not handle related tables.
This api is new to me and at the moment I need to get a working version asap.
Once it done, I do plan to  figure how everything works while I clean up the code.
Will review what you sent and let you know if I have any questions
Chris
MatthewLewis
No problem, give me a shout if you need more help. I'm not always online but I try and check it regularly
joepublic
Mathew, et al
I tried redoing my code similar to what attaching but have encountered errors. So I am back to my original code and was able to solve the TypeError.
Now for the last part.....  I need to be able to click on the countries highlighted (based on the button clicked). Clicking on a highlighted country, triggers a query of the related table (tableURL) and the results of the query are displayed in the side panel on the right.
Can you or someone show me how I can add an  onclick event and a relatedquery to my script?
Hope what I want makes sense
