Getting a polygon of ArcGIS Road Network
832
04-11-2022 04:29 AM
orahlagi
I know different maps providers holds the road network, ArcGIS should have this too because the routing is provided via this data.
The main goal is to get the road network and make a map matching along with a GPS trace.
Is there a way to retrieve this data?
Noah-Sager
Hi @orahlagi, what specifically are you trying to accomplish with your workflow? What information are you hoping to obtain from the road network?
orahlagi
Thank you.
As i said, The main goal is to get the road network and make a map matching along with a GPS trace.
With the road network, i can try to match my GPS coordinates to the closest road using some algorithm.
