Getting 304 errors with OverviewMap
5233
16
12-10-2013 06:24 PM
PattyJula
Hi, I have a feature layer and scale bar working properly in a web page with the JavaScript API. When I add an Overview Map, I get 304 errors and can only see an info box when I open the page. My code is below.
<!DOCTYPE html> <html>   <head>      <meta http-equiv="Content-Type" content="text/html; charset=utf-8">     <meta name="viewport" content="initial-scale=1, maximum-scale=1,user-scalable=no">     <title>LA Collisions</title>     <link rel="stylesheet" href="http://js.arcgis.com/3.7/js/dojo/dijit/themes/claro/claro.css">     <link rel="stylesheet" href="http://js.arcgis.com/3.7/js/esri/css/esri.css">      <style>          html, body, map { height: 100%; margin: 0; padding: 0; }           #info {          background: #fff;          box-shadow: 0 0 5px #888;          left: 5em;          padding: 0.5em;          position: absolute;           top: 1em;          z-index: 40;       }     </style>      <script>var dojoConfig = { parseOnLoad: true }</script>     <script src="http://js.arcgis.com/3.7/"></script>     <script>        var map;        require([          "esri/map",          "dijit/layout/BorderContainer",          "dijit/layout/ContentPane",          "esri/dijit/InfoWindowLite",         "esri/InfoTemplate",         "esri/layers/FeatureLayer",         "dojo/dom-construct",         "esri/dijit/OverviewMap",          "esri/dijit/Scalebar",         "dojo/parser",         "dojo/domReady!"        ], function (            Map,           InfoWindowLite,           InfoTemplate,           FeatureLayer,           domConstruct,           OverviewMap,    Scalebar,           parser       ) {         parser.parse();         var  map = new Map("map", {           basemap: "topo",           center: [-118.5, 34],           zoom: 11         });                 var scalebar = new Scalebar({           map: map,           // "dual" displays both miles and kilmometers           // "english" is the default, which displays miles           // use "metric" for kilometers           scalebarUnit: "dual"         });        var infoWindow = new InfoWindowLite(null, domConstruct.create("div", null, null, map.root));         infoWindow.startup();         map.setInfoWindow(infoWindow);          var template = new InfoTemplate();         template.setTitle("<b>${OMEGA_NAME}</b>");         template.setContent("<b>Collision Count:</b> ${COUNT_}</br>  <b>Area (square miles):</b> ${AREA_MI}</br>");          //add a layer to the map         var featureLayer = new FeatureLayer("http://arcgis-pjula1gistusc-772545567.us-west-1.elb.amazonaws.com/arcgis/rest/services/LAPD_collisions2/MapServer/0", {            mode: FeatureLayer.MODE_ONDEMAND,           infoTemplate:template,           outFields: ["OMEGA_NAME","REP_DIS", "COUNT_", "AREA_MI", "COLL_RATE"],           opacity:.60         });          map.addLayer(featureLayer);         });          var overviewMapDijit = new OverviewMap({            map: map,           visible: true         });         overviewMapDijit.startup();       });       </script>   </head>     <body>      <div id="info">         Click on a reporting district in Los Angeles to get more information.       </div>   <body class="claro">       <div data-dojo-type="dijit/layout/BorderContainer"           data-dojo-props="design:'headline', gutters:false"          style="width: 100%; height: 100%; margin: 0;">        <div id="map"             data-dojo-type="dijit/layout/ContentPane"             data-dojo-props="region:'center'"             style="overflow:hidden;">    </body>  </html>
Does anyone see what I'm missing? I'm using ArcGIS 10.2 and JavaScript 3.7. The feature layer will probably not be visible when you run this code. Thanks! Patty
JeffPace
hope you find the error in lining them up.  Thats the easy answer 😉
PattyJula
I did! Thank you so much! I had not added "dojo/dom-style" to my JavaScript. Now that it's added, the hover tool works with my geocoder and base maps. Thanks again for talking that out with me! 😄 Patty
JeffPace
Happy to help.  I am willing to be almost every developer (myself included) has made that mistake at least once.
Glad you are on the right track.
JonathanUihlein
Thanks Jeff!
Glad everything was taken care of!
Apologies for the delayed response; most of us have been at the DevSummit all week.
JeffPace
sure jon, ill cover for all the developers having fun at the dev conference while I sit here in my cube all week.  🙂
PattyJula
Haha, you should try to make it there next year, Jeff! I attended the first few days - it was great!
JeffPace
I wish, I have never been.
I do make it to the UC every other year, but County Budgets are very volatile.  Plus our Department has gone from 11 people to 5 and our workload has tripled, so not alot of free time.
What I do have I try to spend on here.  Lots to learn, Lots to share (mostly from mistakes I have made myself at one point in time)
