Get x,y from identifed feature(s)
1838
01-10-2014 08:59 AM
JohnPreston
Hi, I would like to get the x,y from identified features when user clicks on map. I would also like to get the count of features found. Does anyone have an exmaple or resource to point me to? Thank you!
Here is code to identify features when user clicks...
function mapReady(map) {
            getLocation();
            dojo.connect(map, "onClick", executeIdentifyTask);
            identifyTask = new esri.tasks.IdentifyTask("http://gisappserv3/ArcGIS/rest/services/Engineering/MaintenancePoints/MapServer");
            identifyParams = new esri.tasks.IdentifyParameters();
            identifyParams.tolerance = 5;
            identifyParams.returnGeometry = true;
            identifyParams.layerIds = [2, 15];
            identifyParams.layerOption = esri.tasks.IdentifyParameters.LAYER_OPTION_VISIBLE;
            identifyParams.width = map.width;
            identifyParams.height = map.height;
function executeIdentifyTask(evt) {
            identifyParams.geometry = evt.mapPoint;
            alert(identifyParams.geometry('x'));
            identifyParams.mapExtent = myMap.extent;
            var deferred = identifyTask.execute(identifyParams);
            deferred.addCallback(function (response) {
                return dojo.map(response, function (result) {
                    var feature = result.feature;
                    feature.attributes.layerName = result.layerName;
                    console.log(feature.attributes.Location);
                    if (result.layerName === 'Maintenance Districts') {
                        $('input:radio[name="radioMaintDist"]').filter('[value="' + feature.attributes['District'] + '"]').next().click();
                    else {
                        $('#popStructureType').val(feature.attributes['Display Name']);
                    $('#popSWUStructure').popup('open');
                    var template = new esri.InfoTemplate("", "Facility ID: ${Manhole I.D.} <br/>");
                    feature.setInfoTemplate(template);
                    return feature;
KenBuja
MVP Esteemed Contributor
But you can get back many results from executing an IdentifyTask
identifyTask.execute(identifyParams, function (results) {      console.log(results.length); });
JohnPreston
I was able to figure out how to get the x,y by adding this code in the return dojo.map(response, function (result) {...
var mp = result.feature.geometry
alert(mp.x + " " + mp.y);
I still want to be able to county the number of features identified.
JonathanUihlein
Documentation for result of an IdentifyTask:
https://developers.arcgis.com/en/javascript/jsapi/identifyresult-amd.html
As you can see, it returns one feature (as a graphic). You've already discovered result.feature.geometry.x and result.feature.geometry.y, but it is all outlined in the documentation.
Hope this helps!
KenBuja
JohnPreston
Thanks Jon and Ken!
