Get user current view polygon coordinates
2526
03-29-2022 01:50 AM
orahlagi
i know there is a way to get the user's current mouse coordinates, but i wonder if there is a way to get the user's current view polygon, which means the coordinates of each corner on the map.
The reason behind this, is that i want to show the user points that are only on his current view range, so i need to know which points should i fetch and which not.
Thanks.
collaarwaar
@orahlagi these are 'real' coordinates but in I guess Webmercator-projection (wkid 3857), you want them in geographic coordinates (WGS84 wkid 4326)?
In that case there's a geometry-method to reproject webMercatorToGeographic , that might help you?
orahlagi
Update: using the watchUtils i can get the 'extent' property which gives me xmin,xmax,ymin,ymax.
I'm not sure how this data can help me to get the real coordinates, maybe someone can shed some light.
JohnGrayson
Esri Alum
Depending on how you're going to use it, you should be able to directly use the MapView.extent as the 'search/selecting/etc' geometry.  If you absolutely need the geometry as a Polygon then maybe check out the 'fromExtent()' static method.
orahlagi
Thanks.
I need the geometry for the server, so i am able to get a polygon from the extent, and i'm getting "rings" array which are the xmin,ymax etc of the extent, question is, can i convert it to real coordinates somehow?
0: (2) [-9287098.97013145, 4619242.716943042]
1: (2) [-9287098.97013145, 5326132.3545241635]
2: (2) [-7173768.012103459, 5326132.3545241635]
3: (2) [-7173768.012103459, 4619242.716943042]
4: (2) [-9287098.97013145, 4619242.716943042]
collaarwaar
