get initialExtent instead of fullextent
1234
08-28-2024 03:33 AM
LionelGOUBET
I don't understand why the initial extent is not available to build a map on a MapImageLayer ? only fullextent is available
var mapImageLayer = new MapImageLayer({
url: "URL_DU_MAP_IMAGE_LAYER"
mapImageLayer.load().then(function() {
// Obtenir l'étendue initiale du MapImageLayer
var initialExtent = mapImageLayer.initialExtent;
console.log("Étendue initiale du MapImageLayer : ", initialExtent);
// Créer la vue de la carte en utilisant l'étendue initiale
var map = new Map({
basemap: "streets",
layers: [mapImageLayer]
var view = new MapView({
container: "viewDiv", // ID de l'élément HTML où la carte sera affichée
map: map,
extent: initialExtent
}).catch(function(error) {
console.error("Erreur lors du chargement du MapImageLayer : ", error);
the only solution is used the rest api with ?f=json
Thanks for your explanation
JoelBennett
MVP Regular Contributor
The MapImageLayer class doesn't expose an initialExtent property, but the value can still be retrieved from its sourceJSON property.  See line 7 below, which also uses Extent.fromJSON:
	var initialExtent = Extent.fromJSON(mapImageLayer.sourceJSON.initialExtent);
	var map = new Map({
		basemap: "streets",
		map: map,
JoelBennett
	var map = new Map({
		basemap: "streets",
		map: map,
LionelGOUBET
Thanks Joel 😀
... I missed it 🙄
