Get graphic attribute from GraphicsLayer using hitTest with 4.24 api
6676
7
08-30-2022 12:55 PM
PeteVitt
Hi - I'm trying to access the graphic attribute of a hitTest on a graphicsLayer.  The code below was working with 4.22, but not now at 4.24
        // Search for graphics at the clicked location
        a.view.hitTest(screenPoint).then(function (response) {
          if (response.results.length) {
            var graphic = response.results.filter(function (result) {
              // check if the graphic belongs to the layer of interest
              return result.graphic.layer === a.graphicsLayer;//at 4.24 this does not compile Property 'graphic' does not exist on type 'ViewHit'
              //try this as hitTestResult is array of result objects at 4.24
              return result[0].graphic === a.graphicsLayer;// TypeError: Cannot read properties of undefined (reading 'graphic')
            })[0].graphic;
            //call method on form component to open closeout form work order
            a.comService.WorkOrderClickedOnMap(graphic.attributes.WorkOrderID);
strangely, when I break on result I see a graphic property (see below).  Any ideas how to get this to work?
Thanks
Pete
Tags (1)
ReneRubalcava
Esri Frequent Contributor
hitTest is right, you just need to access the results slightly differently as of 4.24.
The documentation explains the 4.24 change and has some snippets.
https://developers.arcgis.com/javascript/latest/api-reference/esri-views-MapView.html#hitTest
view.on("click", async (e) => {
  const response = await view.hitTest(e);
  const result = response.results[0];
  if (result.type === "graphic") {
    const graphic = result.graphic;
  else if (result.type === "media") {
    const element = result.element;
  else if (result.type === "route") {
    const networkFeature = result.networkFeature;
ReneRubalcava
This is probably due to the hiTest updates listed in the 4.24 release notes here.
https://developers.arcgis.com/javascript/latest/release-notes/#mapview-and-sceneview-hittest-updates
You might want to check for the result type. If you have a repro of your issue, could take a closer look. Is this a TypeScript error? If you check the result.type first, it might help TypeScript narrow the type correct to a GraphicHit.
This sample still uses hitTest
https://developers.arcgis.com/javascript/latest/sample-code/sandbox/?sample=view-hittest
PeteVitt
Thanks Rene - maybe this is a typescript thing -- do you know of any other methods I could try to access graphic attributes of a clicked graphicsLayer other than hitTest?
ReneRubalcava
PeteVitt
Thanks Rene - that did the trick!
PeteVitt
no graphic propertyHitTestResultIntellisense.jpgHitTestResultIntellisense.jpg
Mr_Kirkwood
 How can i make it so that i can use multiple layers? I have this onclick fucntion:
view.on ("click", function (event)
                // Handle feature selection here
                console.log ("Get Selected Features Data")
                $ ('#customWindow').jqxWindow ('close');
                 $ ('#assignedEmployeesTable').jqxGrid ('clear')
                view.hitTest (event).then (function (response)
                    if (response.results.length > 0) {
                        const features = response.results.filter (function (result)
                            return result.graphic.layer === roomsUseLayer;// Filter for your specific layer
                        // Extract attributes from the selected features
                        features.forEach (function (feature)
                            attributes = feature.graphic.attributes;
                            console.log (attributes.SPACEID);
                        getSpaceObjectID ();
Mr_Kirkwood
The code below wroks well for a solution:
view.on("click", function (event) {
    console.log("Get Selected Features Data")
    view.hitTest(event).then(function (response) {
        for (let i = 0; i < response.results.length; i++) {
            const result = response.results[i];
            attributes = graphic.attributes;
            const layer = result.layer;
            console.log("Layer:", layer.title);
            console.log("Attributes:", attributes);
            console.log(attributes.OBJECTID)
            getObjectID();
