Get agol Login user name using Esri js api 4x
1798
07-09-2021 03:04 PM
divyabathina
Hi ,
How can we the login user name when accessing secure agol maps using Esri JS api 4x application .
Divya
ReneRubalcava
Esri Frequent Contributor
You can do this in the following steps:
  1. Register OAuthInfo with IdentityManager.
  2. Construct and load Portal.
  3. You can now access the Portal User.
divyabathina
Hi Rene,
Ill try this and update you back,
Divya
