Geometry Task Project Bug
1403
08-10-2011 01:56 PM
JulianoKersting
Hello I'm having problems using the geometry service project method.
I get the following error: "
Message: 'spatialReference' is null or not an object
Line: 48
Char: 410823
Code: 0
URI: http://serverapi.arcgisonline.com/jsapi/arcgis/?v=2.4
The code is very simple, I am just trying to project a mapPoint from projected (26911 ) UTM NAD81 Z11 to WGS84 (4326 ) using the geometry service.
// explicit SR definition for input point
var ptUTM = new esri.geometry.Point(mapPoint.x, mapPoint.y, new esri.SpatialReference({ wkid: 26911 }));
                    var outSR = new esri.SpatialReference({ wkid: 4326 });
                    var ptWGS;
                    gsvc.project(ptUTM, outSR, function (projectedPoints) {
                        ptWGS = projectedPoints[0];
Any Inputs?
HemingZhu
Line: 48
Char: 410823
Code: 0
                    var ptWGS;
Any Inputs?
gsvc.project([ptUTM], outSR, function (projectedPoints) {
The first parameter is Geometry[].
JulianoKersting
Thank you! Its working now.
