Geometry Service
2070
05-24-2021 11:32 AM
EricHermoso
I am using GeometryService version 4.0 to convert state plane coordinates to geodetic position. But I am receiving timeout exceeded error.  I have 400 points that I want to convert to geodetic position but I was only able to get about 50 points converted. When I use ESRI geometry projection service version 4.7 it works. Since we are currently using the version 4.0 is there a way to convert all 400 points without timing out.
Code Sample:
require(["esri/geometry/projection", "esri/geometry/SpatialReference","esri/geometry/Multipoint","esri/tasks/GeometryService","esri/tasks/support/ProjectParameters","esri/geometry/Point"], function(ProjectParametersSample, SpatialReferenceSample,MultipointSample,GeometryServiceSample,TaskSupportProjectParameters,SinglePointService) {
var outSpatialReference = new SpatialReferenceSample({
wkid: 4326
var count = 0
//var geometryService = new GeometryServiceSample("https://utility.arcgisonline.com/ArcGIS/rest/services/Geometry/GeometryServer"); // https://utility.arcgisonline.com/ArcGIS/rest/services/Geometry/GeometryServe
sdfs.forEach(function(point){
// console.log(point[0])
// console.log(point[1])
var inpoint = new SinglePointService(point[0],point[1],new SpatialReferenceSample({wkid:2230}))
var params = new TaskSupportProjectParameters({
geometries: [inpoint],
outSpatialReference: outSpatialReference,
var geometryServiceProject = geometryService.project(params).then(function(resultL){
console.log(count += 1)
Noah-Sager
@EricHermoso it's difficult to say since version 4.0 has been retired. We are currently on version 4.19, and we recommend using the latest version for production applications as much as possible.
https://support.esri.com/en/products/developers/web-apis/arcgis-api-for-javascript#product-support
Noah-Sager
