Geometry engine clip method output shift issue
1404
06-13-2019 06:42 AM
Harsha
        I am using the clip method of geometyEngine API.After executing the clip method on the inputgeometry using an envelope the input geometry is being cliped but it not clipping exactly.It is clipping with some shift in the geometry.Can any one help me in this regard.
Please find the attached code and screenshot related to this issue.
Regards,
Kishore Kumar
RobertScheitlin__GISP
Kishore,
   The image looks exactly correct if you are cliping by the other geometries envelope. What you have to understand is that a geometries envelope is rectangle that the geometry will fit inside of.
