Geodesic Measurement Algorithm Used in ArcGIS
2193
08-07-2019 11:53 PM
by Anonymous User
Not applicable
Hi Guys,
I would like verify that current geodesic measurement algorithm used in ArcGIS server is the same as the one published by Karney as below link?
Geodesic calculations for an ellipsoid done right
MelitaKennedy
Esri Notable Contributor
We are using Vincenty with some adaptions for near-antipodal cases for distance/geodesic line calculations. We are aware of Karney's publications and may switch to his at some point in the future.
Melita
MelitaKennedy
Melita
by Anonymous User
Not applicable
Thank Kennedy,
Geo-scientists at my client side keen on looking forward to having it.
May I know the release plan?
Is there any suggested workflow to customize or add that measurement algorithm to ArcGIS environment.
One way I am thinking of it as providing as one add-in or extent the measurement add-in of the ArcGIS pro.
What do you recommend?
DanPatterson_Retired
geographiclib · PyPI implements Karney's algorithm
MelitaKennedy
There's no way to override / replace the algorithm in the existing tools or functionality. You would have to write an add-in.
Melita
by Anonymous User
Not applicable
Thank Melita,
We shall do the new add-in with Karney's algorithm.
